Author Topic: DIF main caps  (Read 3161 times)
6667fan
  • Every Second Counts
DIF main caps
« on: December 06, 2024, 09:29:06 AM »
Need (3) main caps, ( rear one not needed). I specified DIF as the bloc is a 69 390. The DIF caps have a circle on top. The MCC ones have a triangle? As the block will need align boring does it matter?
Can the MCC caps be used on DIF block?
Thanks,
Jim
JB
67 Fairlane 500
482 cid 700/617
10.55@125.74 1.46 60’
pbf777
Re: DIF main caps
« Reply #1 on: December 06, 2024, 11:16:51 AM »
      Swapping main caps can be a bit of a crap-shoot as to whether they will really end up fitting properly or even acceptably; this even after a reasonable effort in line-bore/hone correction.   :o
      The problem is that when the blocks were originally machined by Ford, they didn't seem to really care to much as to whether the cap to block parting line actually bisected the hole through it's center, nor whether the block to cap locating registers were actually equal distances from the center either.  After all, if they had done so accurately, then all of the caps could be swapped in positions on the block, or even from block to block without any concerns for ill fitment.   :(
      So..................the closer to the same production run that the substitute caps might come from, generally the better the chances that the resultant fitment might be found to be acceptable.   ;)
      Scott.
Urgefor
Re: DIF main caps
« Reply #2 on: December 09, 2024, 01:12:29 AM »
Everything Scott mentioned is covered in fairly decent detail in this thread.
It can be an adventure for sure.  I would also suggest that the machine work is performed by someone that you know understands the job at hand and can do it right the first time.
