Author Topic: Dyno test on the progenitor of the FE  (Read 15662 times)
Royce
« on: August 14, 2013, 10:35:28 AM »
I had my Lincoln Y Block on the R&R dyno this week with some satisfying results.
It is a 383 inch 4.06 x 3.7  12:1 with ported stock heads.. 248@.050 .625 lift cam  Hilborn injection.
 A lot of old tech in this one
1961 Starliner 390/375 clone
1965 GT40 tribute w/FE
1992 BMW V-12 5.0
2001 Lincoln 5.4 4 cam
2000 Jaguar XK8 (Ford V8)
Re: Dyno test on the progenitor of the FE
« Reply #1 on: August 14, 2013, 10:43:51 AM »
500 Horse!  Attaboy, Royce.  1.3 HP per cube is a great result for the ol' hot rod Lincoln.  Got any photos of the engine on the dyno?
« Reply #2 on: August 14, 2013, 10:50:17 AM »
Holy Cow!!! Good numbers! (But then I remember the rumours going around during about 1960 within the somewhat sparse FoMoCo performance community. The only things to talk about were the 352 360 and some work that was being done in Dearborn on the Lincoln engine. At the '59 Nationals a Lincoln-powered 'kit' car did very well in Modified Sports.
What's it going in?
Royce
« Reply #3 on: August 14, 2013, 11:08:16 AM »
A couple of pictures on the R&R dyno
1992 BMW V-12 5.0
Royce
« Reply #4 on: August 14, 2013, 11:13:29 AM »
another
1992 BMW V-12 5.0
Royce
« Reply #5 on: August 14, 2013, 11:17:07 AM »
It is going in this car... It should get me my 9 sec time slip
1992 BMW V-12 5.0
« Reply #6 on: August 14, 2013, 11:26:00 AM »
Those valve covers are COOL!  You need to get some bells on those velocity stacks.  Should look good in the race car.  Will you be heading back to Slippery Rock with that one? ;D ;D
Royce
« Reply #7 on: August 14, 2013, 11:34:56 AM »
If you can get JC to crew for me at slippery rock I will go....
As for bells , I had to shorten some existing stacks since this whole system is kind of a cut and paste deal.  I can only fit a 5 inch stack and the bells would have to be siamesed.. Now if I just knew a guy with a CNC and a lot of design talent.....
Valve covers come from a Continental MK II
« Last Edit: August 14, 2013, 11:38:37 AM by Royce »
1992 BMW V-12 5.0
« Reply #8 on: August 14, 2013, 04:35:00 PM »
Now that is cool!! I love the old front engine rails, and that engine is perfect in there. Looks like a rock solid and dead flat power band right where you want it too! The wheels look just a little out of place though, but I wouldn't kick her out of my garage :)
Very very nice, Royce! It's neat to see the '50s engines make a comeback. They kinda got lost in the shuffle between flatheads and the newer engines.
Royce
« Reply #9 on: August 14, 2013, 05:52:15 PM »
I Concur on the wheels.  It now has Torque Thrusts on the front and slots on the back.. It's really hard to find a 12 inch aluminum slot with the correct offset
1992 BMW V-12 5.0
« Reply #10 on: August 15, 2013, 06:57:36 AM »
Very cool Royce, both the car and the engine  :). Would like to see a few more dragster pics from other angles.
One question: are the smallish size of those ancient Hilborn throttle bores holding back some hp production?
I ask since IIRC correctly the bores are pretty small compared to later model versions for other engine makes.
« Last Edit: August 15, 2013, 07:21:56 AM by machoneman »
garyv
« Reply #11 on: August 15, 2013, 07:00:07 AM »
That is one Bad Lookin' Ride !
Love it
garyv
Royce
« Reply #12 on: August 15, 2013, 08:38:18 AM »
Yes the throttle bores are smallish at 2.06   Smallest Hilborn makes currently is 2.375
Here is a picture at the Meltdown drags at Byron Ill from last year
1992 BMW V-12 5.0
Royce
« Reply #13 on: August 15, 2013, 09:06:33 AM »
JC and I got a little ink.
1992 BMW V-12 5.0
« Reply #14 on: August 15, 2013, 03:21:33 PM »
I was wondering how you got in that thing, but was afraid to ask...lol
And those Torque Thrusts and slots look so much better than the Lites. That is just a super cool car, Royce! What state are you located in? I'd love to see it run sometime.
And what is going on with the hose into the water pump spot on your old engine? Do you have a separate pump to pump water through the engine?
« Last Edit: August 15, 2013, 03:24:37 PM by cjshaker »
