Author Topic: 'Line Bore' Timing Chain Sets  (Read 3806 times)
66FAIRLANE
  • Andy
« on: September 19, 2024, 06:04:52 PM »
I have always wondered how you know if one will fit? Is there a centre to centre spec that dictates the use of a line bore set?
Re: 'Line Bore' Timing Chain Sets
« Reply #1 on: September 20, 2024, 09:08:18 AM »
The hill Billy method is when you bolt on a new timing set and the chain is loose, if you know the engine has been built a few times then you can assume you need one or bolt another standard timing set on just to verify the first set was correct and not flawed and then go tighter set
BigBlueIron
« Reply #2 on: September 23, 2024, 01:09:06 PM »
Standard center distance of 5.044 The last Cloyes I used was advertised as 0.005 in Reduced Center Distance.
66FAIRLANE
  • Andy
« Reply #3 on: September 23, 2024, 08:56:57 PM »
Ahhh, so they specify a centre to centre reduction. Thanks BigBlueIron. This is what I was after.
