Author Topic: SOLD - solid roller cam  (Read 3677 times)
« on: September 15, 2024, 12:29:20 PM »
Solid roller Comp street cam, used.
Comp Cams custom grind, not by me, it was in the engine.  Xtreme Energy Street roller, lobes 4874/4875 on 110 LSA ground with 4 degrees advance.
280/286 advertised,  242/248@.050, 164/170@.200, .380/.384 lobe lift for .668/.675 with a 1.76 rocker. 63 degrees overlap would have vacuum for brakes on a stroker
Spintron designed as a street lobe with a more gentle closing ramp and relatively tight last at .015. 427 cid or bigger FE unless you are wilder than me :)   300.00 plus shipping, will throw in the matching lifters but I cannot at all say that a used solid roller lifter is appropriate for use...if you want them they are free and come with no promises
Double roller timing chain, matching torington bearing cam retainer plate.
Has torrington bearing behind timing set and in front of cam.  Nice piece, not sure if PoP or someone else, but not planning to use   Chain was nice and  tight at disassembly.  50.00 plus shipping.
Both ship from Omaha, NE area, can email My427stang@yahoo.com or reply here, first reply and pay, first serve
« Last Edit: September 23, 2024, 06:08:13 AM by My427stang »
Ross, I'll take the cam and lifters.
I'll send a Email.
Frank, I got your email, appreciate it.
Bogged down a bit today, I will reply tonight.  Thanks
