Author Topic: Toploader hydraulic throwout bearing  (Read 5949 times)
allrightmike
« on: September 07, 2024, 08:16:01 AM »
Switching from C6 to big input Toploader. Is there a hydraulic throwout bearing setup using OEM production components. The aftermarket conversions seem to be rather lavishly priced. I do have machining ability and machines in case modifications are required.
'60 Starliner 427 4speed.
Jb427
Re: Toploader hydraulic throwout bearing
« Reply #1 on: September 07, 2024, 11:59:08 AM »
Mine replaced the front seal cover
Not sure if there is much option for big shaft toploader
allrightmike
« Reply #2 on: September 07, 2024, 12:59:22 PM »
What brand is that and do you have it up and running?
Jb427
« Reply #3 on: September 07, 2024, 02:31:59 PM »
Brand is Mal woods and mine was made for a lakewood scatter shield
Ford small shaft toploader they just slide over the cover. I am not aware of one for a bigshaft toploader one that dose not replace the cover.
fitter
« Reply #4 on: September 07, 2024, 03:40:09 PM »
I purchased a McLeod unit from modern drive line . After fighting it for a year and pulling trans several times I spoke to modern driveline. Bruce said. Ya we had a lot of problems with those and no longer sell them. If you don’t like it talk to McLeod. They were equally helpful. Ended up giving it away and going external . Unless they have improved. I would not recommend McLeod.
Jb427
« Reply #5 on: September 07, 2024, 06:58:31 PM »
Mine worked good I also had a Mal Woods under dash master cylinder. Only problem I had was the heavy clutch pedal that was more to do with the clutch and under dash pedal box ratio. I also had to run a spacer plate between the box and the bellhousing it was around 2 to 3mm thick.
I ended up swapping to C6 due to my father not being able to hold the clutch in at 73 years old.
But I will swap back in a few years and get Mal woods to fix the pedal ratio and or change the clutch to make it more user friendly.
PaulProe
« Reply #6 on: September 07, 2024, 08:22:29 PM »
JB427  I am hoping to learn from your experiences. I am running a Lakewood bellhousing with a Ford short shaft TKO600 (TCET4617) and a McLeod pressure plate. The clearance for a hydraulic bearing is minimal and it looks like the Malwood may fit. Do you know what size master cylinder you were using?
Paul
Jb427
« Reply #7 on: September 07, 2024, 10:12:57 PM »
Mal Woods is local to me and he had to custom make it. I will have to look at the master cylinder sizes I ended up getting a second master cylinder that was larger to try and make the pedal softer and it did not really help that much. I will check the installed length for you as well.
Jb427
« Reply #8 on: September 07, 2024, 11:13:49 PM »
clutch master cylinder was 5/8 not sure on the second one but is was bigger 11/16 I think I could be wrong on those sizes but they should be pretty close
From the face of toploader case to the throwout bearing face is 79.4mm or 3.125 inches.
« Reply #9 on: September 09, 2024, 03:42:27 AM »
You should go smaller on the master to get softer pedal. Longer stroke less effort
Jb427
« Reply #10 on: September 09, 2024, 06:16:53 AM »
Im not sure what one was first but I had one of them came with my pedal box after Mal woods made the new pedal and it was almost no change when I got the second size. Clutch was solid centre deal. I will get Mal woods to sort it out when it is time to put it back in.
