Author Topic: How to determine which springs and retainers to use?  (Read 2944 times)
fairlaniac
« on: September 04, 2024, 05:58:46 AM »
Another area that I don’t know much about but want to understand in this lifetime. How to determine which valve springs to use? I have a 390 short block that was originally in my ’66 Fairlane. I have a 282S cam in it and nothing else too special. I want to drop it in a ’78 F150 that I’m playing with. I have an Edelbrock Performer intake, a finished set of C6AE-R heads, nothing special done to them. Stock valves. A set of OEM adjustable rockers is what I plan to use. I’m just trying to use parts lying around and just have a mild operating 390. With the 282S cam what springs and retainers would I use?  My original kit came with 972-16 springs which are long gone. Between myself and local friends there may be some parts floating around I could use. I’d to know how to determine a range of retainer diameter and a range of springs (rate and diameter) that could be used.
I hope I was somewhat clear?
Thanks!
Doug Bender
1966 Fairlane 427+/5 Spd TKX
1978 F150 2WD 390
Re: How to determine which springs and retainers to use?
« Reply #1 on: September 04, 2024, 06:21:26 AM »
You pick a spring based off of your head's install height and the camshaft.  The camshaft will dictate spring loads and coil bind clearance.
Once you have a spring picked, then you choose a retainer and locator that will fit it.  Most manufacturers will list a spring and the associated retainer/locator.
The spring loads can vary for a cam, depending on which head you're using and what displacement the cam is in.  A cam will peak higher with a smaller engine and/or a better performing head.  It will peak lower with a big engine and/or a lower performing head.  The higher the rpms, the more spring load you'll need to handle it.
For a 390 with C6 heads, factory valve weight, etc., I'd aim for somewhere around 120 lbs seat and 320-330 open.  The exact spring will depend on your install height, which will vary depending on the valve job, etc., but should be somewhere around 1.800-1.850".
fairlaniac
« Reply #2 on: September 05, 2024, 04:53:21 AM »
Thanks Brent!
Doug Bender
1978 F150 2WD 390
