Author Topic: Timing settings for Terminator x  (Read 3314 times)
482supersnake
« on: August 30, 2024, 01:40:42 PM »
No that I have my motor running with the Terminator x stealth,  what should my timing settings be in the handheld?
Re: Timing settings for Terminator x
« Reply #1 on: August 31, 2024, 09:06:35 AM »
What are the details of your build? and are you dynoing or just going to run it?
Timing on the handheld is pretty basic but works, you can get more precise using a laptop.
However, there are a couple of things you need to do
1 - Make sure you are precise in distributor setup
2 - Set the cam choice based on expected vacuum, (stock >14, street/strip about 7-14,  race under 7 inches)
3 - I have had some versions that allow both idle timing and WOT, but not all have the choice.  If you have it, put idle at 16, if you don't and only have WOT, I'd start at 34
4 - Do a static timing check, (Tune>sys>static timing, set 30)  Fire it up and read timing.  If the light matches the 30, good, if not, turn the distributor to make it match)
With cam specs, compression, heads, cid, etc i can get closer on timing numbers, but in the end, the handheld will only give a basic curve, you'd need a laptop to change things along the curve
Last thing, handheld, ECM and laptop all have to be on the same version, and the latest versions generally fix a lot of odd things.  So once you get it running, recommend some time learning update procedures.  Remember, each component, laptop, ECM, and handheld , all have operating systems...that is what you update.  The GCF is the file that contains the details, but those parent files change  as Holley does improvements
482supersnake
« Reply #2 on: August 31, 2024, 11:33:34 AM »
452 ci, trick flow heads, 10.5-1 compression hydraulic roller cam 235@.050 620 lift. PI intake, tri-y headers.
« Reply #3 on: August 31, 2024, 11:55:43 AM »
Pretty standard (and strong) TFS build, Street/Strip cam choice, I'd do 35 or 36 total, 16 initial if it gives you the option, of I was doing it on a laptop I'd do  15 crank, 18 initial at idle, start with WOT A/F at  12.5 but it will likely be happier at 12.8-13.0, cruise at 14.3, idle at 14.0, .  Idle speed at 800 and verify static timing as I said last post
Should be very stout, you should be 550+ HP and close to 600 ft lbs
