Author Topic: Fan shroud for a 427 Galaxie  (Read 3123 times)
428Marauder
« on: August 07, 2024, 03:52:17 PM »
I’ve done a bit of research and I know a guy with a 63 R code Galaxie that has a fan shroud on it. It’s a top and bottom metal shroud that he thought was correct for the car, but in fact these cars came without a fan shroud from the factory. I purchased, I think it was from like a 63 Tbird with AC, a 2 piece left and right shroud that wouldn’t work. Someone, I can’t remember, maybe Ecklers, was making a top and bottom fiberglass shroud specifically for this application but they are sold out and I’ve been on a waitlist for like 2 years now with no idea if they’ll ever be made again. It has to look factory. Anybody know where I can get a top and bottom shroud that’ll work? TIA.
428Marauder
Re: Fan shroud for a 427 Galaxie
« Reply #1 on: August 07, 2024, 05:05:25 PM »
Thinking I might try this. I assume if it works on a 64 it will work on a 63.
https://www.fordmuscleforums.com/threads/cheap-fan-shroud-1964-galaxie-guide.653333/
Gregwill16
« Reply #2 on: August 07, 2024, 07:53:06 PM »
I have a 63 R with a shroud, but it is not original to the car. As I stated before in another thread, the 427 cars didn’t receive them, only A/C cars.
The 63 and 64 radiators mount different and that factory 63 shroud mounts in conjunction with how the 63 radiator mounts. Not saying you can’t modify to work though.
428Marauder
« Reply #3 on: August 07, 2024, 08:49:00 PM »
Thanks, Greg.
Is your shroud a 2 piece top and bottom, left and right or single piece?
« Last Edit: August 07, 2024, 08:50:46 PM by 428Marauder »
Gregwill16
« Reply #4 on: August 08, 2024, 06:57:33 AM »
It is two pieces, top and bottom. The bottom has Z shaped brackets that go back and mount on the same mounting bolt as the radiator.
428Marauder
« Reply #5 on: August 08, 2024, 04:42:27 PM »
Have confirmed it was Macs that used to make the repops and they no longer do and they aren’t going to.
428Marauder
