Author Topic: Valve Cover Bolts - AMK  (Read 7636 times)
DuckRyder
« on: August 06, 2024, 08:45:46 AM »
Is is just me or are these too long?
Have AMK F339 Valve Covers - 390/427/428 (STL or ALUM)
Looking to put Repop PBF covers on but these seem to bottom before tightening. I also cant use the same length ARP bolts with Repo Lemans covers and steel so a surprised these are listed for both.
Anyone else run into this or am i just cursed with FE's?
« Last Edit: August 15, 2024, 07:31:21 AM by DuckRyder »
Robert
pbf777
Re: Valve Cover Bolts - AMK
« Reply #1 on: August 06, 2024, 11:13:51 AM »
     No, your not cursed, it's just the norm.   :(
     Scott.
« Reply #2 on: August 06, 2024, 12:24:45 PM »
Welcome to the aftermarket.
DuckRyder
« Reply #3 on: August 06, 2024, 01:52:36 PM »
Ok thanks Gents, as long as it isn't just me.
Back to ARP i suppose.
R
Robert
« Reply #4 on: August 06, 2024, 02:01:43 PM »
R
Good luck with their stuff too.
To be honest, I only use ARP for fasteners that are in high load:  mains, heads, rods, cam.  For everything else, I will use a regular fastener.  One of my best kept secrets is buying a complete external fastener kit from Alloy Boltz.  It comes with *everything* that you need for external fasteners:  oil pan, timing cover, water pump, valve covers, intake, headers, thermostat housing, carb studs, distributor bolt, you name it.  It's about $50-55 for a complete stainless steel bolt kit.
As with every bolt kit, don't always count on the intake bolts being the right length.  Different intakes take different length bolts.
Urgefor
« Reply #5 on: August 06, 2024, 06:39:22 PM »
I became tired of bolts for the valve covers and use studs now instead.  A bit of threaded rod cut to the desired length along with a flange nut and a flat washer. The part I like the most is being able to set the valve cover gasket over the studs and not have to worry about anything while putting the valve cover on.  I use cometic's valve cover gaskets so mileage may vary if you use something like cork.
Dr Mabuse
« Reply #6 on: August 09, 2024, 07:14:05 AM »
I also use studs in many applications, but never threaded rod, except for a carb air cleaner hold down. Any good hardware, auto, or big box store has different length and grade studs. Of course, threaded rod for an exhaust manifold would be a disaster.
« Reply #7 on: August 09, 2024, 08:05:34 AM »
I wonder if you got an odd set? I buy them in bulk from AMK and haven’t had an issue.
« Reply #8 on: August 09, 2024, 09:40:31 AM »
I use studs a washer and stainless acorn nuts
DuckRyder
« Reply #9 on: August 10, 2024, 08:10:20 AM »
I already have 2 different lengths of ARP, i was just trying to look more stockish.
I doo agree it was a lot lot of work to get the right length bolts even with an ARP full engine kit. Especially the intake.
Ross, interesting, ill stick a caliper on mine and see how long they are.
Robert
« Reply #10 on: August 10, 2024, 12:30:16 PM »
I'll check a couple today too
Urgefor
« Reply #11 on: August 10, 2024, 11:25:53 PM »
I had the threaded rod, nuts and washers on hand.  I agree about the studs though.  Had it been any application other than the valve covers (carb excluded), it would have been a proper stud.
DuckRyder
« Reply #12 on: August 11, 2024, 06:42:44 AM »
I get .629 from the lock washer tail closest to the bolt head to the end of the bolt.
Robert
rockhouse66
« Reply #13 on: August 11, 2024, 06:56:14 AM »
The bolt you have is correct; 3/4" long bolt, .62" to the split washer.  AMK sells an identical bolt with the same head marking in 5/8" length.  AMK p/n B-12314 for a package of 4 or B-10192 for a package of 17 (because it is also used for the oil pan on FE without the windage tray).
Jim
« Reply #14 on: August 11, 2024, 10:29:58 PM »
Dr Mabuse---
At least here in Detroit, I suppose because of the plethora of manufacturing entities here, it is entirely possible to go to a bolt/fastener supply and buy 'All-thread' of any material/grade you might need. I have often bought lengths of extra-strength stainless steel to use on such things as suspension fasteners.
We may well be a bit spoiled because of the ease of finding things not available in other parts of the country.
