Author Topic: Cam install question  (Read 2525 times)
Boiler Ben
« on: August 05, 2024, 06:21:50 AM »
I just installed my cam and wondering if I can leave it as is. I had a little trouble with it but not sure if it’s something to worry about.  The crank, pistons and rods are already in and the engine is sitting right side up on the stand.  It’s a steel billet roller cam and it’s lubed.  I have a piece of threaded rod as a handle.
The first section went in fine.  During the second section, the lobes touched the bearing.  It wasn’t really a “drop”, but it did touch.  Seemed like it was probably OK.  The third section was a little tricky.  I had trouble holding it straight enough.  I didn’t force it, just tried to finesse it.  Almost on accident, I rotated the cam in my hand and it moved forward.  So the edge of a lobe must have been touching somewhere.  I tried to be careful and it didn’t seem to scrape but I’m wondering if this is a problem.  I know there was a good layer of assembly lube on it.
If I remove the cam, I feel like I won’t be able to see or feel the bearings good enough. And then I’ll have to do it all over and I doubt my skills are much better now.
Am I over thinking this?  Should I just move on?  It rotates nicely.
Re: Cam install question
« Reply #1 on: August 05, 2024, 07:46:56 AM »
If it turns easy you are almost certainly fine.  Next time, if able, stab before the crank and let it sit there
Boiler Ben
« Reply #2 on: August 06, 2024, 05:58:34 AM »
That gives me a little confidence. I didn’t really understand the recommendation for next time though.  Do you mean take a pause between sections?  So since it turns nice, is the consensus that I’m good to go?
« Reply #3 on: August 06, 2024, 07:49:47 AM »
If you're ever doing a build from the ground-up again, I always put the cam in first.  That way, with the block upside down on the stand, you don't need any cam handles or anything like that.  You can reach in and guide it with your other hand.  Also know that just by design, you have to rotate the cam back and forth as you slide it in.  You will inevitably get some kind of a little clunk or something like that as you put it in.
Boiler Ben
« Reply #4 on: August 06, 2024, 08:51:30 AM »
Understood. If it’s possible, that certainly sounds like an easier way to do it. Thanks for the help. I am moving on.
