Author Topic: valve spring tool  (Read 2953 times)
sixty9cobra
valve spring tool
« on: June 21, 2024, 09:28:15 AM »
i am looking for a valve spring to use with heads on my wngine.It should be tough enough for roller cam springs.
mike7570
Re: valve spring tool
« Reply #1 on: June 21, 2024, 10:20:45 AM »
I used one from LSM for shaft rockers. (Sold at Summit) had to open up the mounting holes in the base to work with FE bolt size and spacing. Worked great with air compressor to hold valves up.
« Last Edit: June 21, 2024, 11:41:21 PM by mike7570 »
