Author Topic: Who has installed 10" slicks on a comet or fairlane  (Read 12962 times)
manofmerc
« on: June 07, 2024, 04:08:37 AM »
My local track prep is inconsistent. I have 9x29.5 mickeys 3056st sometimes I hook sometimes I dont.This a a 460 based 502 c-6 loosened convertor went to a 3.70 from a 4.10 .Tried every setting on my cal tracs new hoosiers new mickeys both spun hoosier has a 10" with 11.00 section width #18158 curious if you all think this would work .Doug
manofmerc
Re: Who has installed 10" slicks on a comet or fairlane
« Reply #1 on: June 07, 2024, 04:15:18 AM »
I gave the wrong #sorry!it is #18150 with a 10.3 " section width
6667fan
  • Every Second Counts
« Reply #2 on: June 07, 2024, 09:20:10 AM »
What are you running for slick pressures? Launch rpm? What is the contact patch?
Should be a way to hook them up
« Last Edit: June 07, 2024, 11:19:31 AM by 6667fan »
JB
67 Fairlane 500
482 cid 700/617
10.55@125.74 1.46 60’
« Reply #3 on: June 07, 2024, 09:48:14 AM »
How heavy is the car, what ET, MPH, and 60 foot times? And what do you have for front suspension setup? Wheel width and tire pressures? There are plenty of low 10 second/high 9 second Fairlanes racing in NHRA Stock Eliminator on 9" slicks. "Loosened convertor" is very vague, what is the actual stall speed? What are you launching the car at? Using a transbrake? Also curious why you are using a stickshift tire with an automatic transmission.
hbstang
« Reply #4 on: June 07, 2024, 02:22:15 PM »
the front suspension plays a big part with cal tracs.90/10 shocks moroso springs,not stock springs or heavy road race springs,battery in the trunk etc.front end lift on launch is really important for them to work.also roller bearing spring perches,every thing works together for wieght transfer.also if you have iron heads and placment of the engine fore and aft makes an impact.
« Last Edit: June 07, 2024, 02:24:58 PM by hbstang »
pumpbldr
« Reply #5 on: June 07, 2024, 10:56:47 PM »
I went through all this along time ago. I had a ranchero, even lighter in the ass end. I did everything everyone is mentioning: 90/10's, Caltracts etc. The Rear tires wer 28 x 10.5 on Weld 10'' with 5.5 back spacing. To get them to fit there is about 2" between the inner wheel tub to the frame. I cut the 2" out and with some clamps and heat did a mini-tub with stock wheel tub pushed toward frame , then welded. Also did some grinding to wheel lip. All fit no problem. Was much better after that. Here is the golden ticket I share. An older timer told me to get some crap rear shock that sag. I believe WTF was my answer. But I listened some more. Also said to get a pinion snubber. Let the ass end sag, weight transfer to back and get the bottom of car to drive the snubber into the earth. That solved all my issues. Food for thought.
Doug aka pumpbldr
Precision Oil Pumps
manofmerc
« Reply #6 on: June 08, 2024, 04:11:52 AM »
I will give the best answers I can .I have cheap 90/10 shocks on the front with smallblock torino springs It has a transbrake the stall is 4500 9" ati convertor Calvert springs with their rear shocks setting is at 1 (calverts recomendation The reason I use that 4spd slick is also calverts idea I also run m/t 3056st another stiff sidewall tire the rims are 8" I plan to purchase calverts front 90/10 shocks just to see if there is a difference A hooking 60 ft.1.43@6.62 A not so hooking 1.60s I spoke with the hoosier guy he said that tire wouldnt be worth the expence and trouble .With excellent prep it hooks fine so-so prep it spins off the line I had a smaller engine it hooked consistently with this 502 not so . The cam has a 108 in centerline I installed it + 2 at 106 really thinking about a 4-6 degree retard cam is 256-266 108 ls 620 lift I have thought about moving my springs in so I could put a really big tire in there but somehow I believe I am just missing something I have tried my two step at 2400-3400 it spins less at a lower rpm.If I missed something I will check back with you all tomorrow
manofmerc
« Reply #7 on: June 08, 2024, 04:14:56 AM »
Tire pressure 13.5-12 battery in trunk
JamesonRacing
« Reply #8 on: June 08, 2024, 08:16:44 AM »
Doug aka pumpbldr
Precision Oil Pumps
I remember seeing your Rancheroi at a FPP show back in the 1980's.  Seemed like you had it well thought out and the car (truck?) was put together really well.  Are the rear springs farther inboard on a Ranchero than a Fairlane?
6667fan
« Reply #9 on: June 08, 2024, 11:40:08 AM »
The 90/10s are great for weight transfer and potential air under front runners but the compression is too little imo. My 67 would be pogoing 1-3 gear shifts. I never hit the Canton pan or Crites tubes but it must have been very close. I switched to Viking DAs on the front. Extension is nearly the same, (still tuning), but the controlled compression has car much more stable through upshifts.
On the footprint, if you make the decision to get a 10.5 tire under there the extra total 3” +/- of rubber will make a profound difference.
JB
67 Fairlane 500
482 cid 700/617
bsprowl
    • Ford FE Information
« Reply #10 on: June 08, 2024, 09:24:02 PM »
Wagons and Rancheros do have narrower spring mounting points.  Around 1- or 1-1/2 inches less (total) as I recall.
manofmerc
« Reply #11 on: June 09, 2024, 04:19:54 AM »
66-67 My thought exactly .Just lot of work and a fair amount of money then what to do with all my left over slicks and wheels >Somehow I am missing something as others have said it should hook with these 9" tires and sometimes it does .Sometimes doesnt win races .Thanks you all .Doug
price5113
« Reply #12 on: June 11, 2024, 01:57:35 PM »
Have you weighed your car on all 4 corners? If Im reading your post correctly, your using the REV limiter on launch? Have you tried leaving off of just the transbrake?
« Reply #13 on: June 11, 2024, 02:27:05 PM »
I fought the same battle years ago, and finally talked with a Stock Eliminator National Champion about this.  He opened my thought process with a statement that a 9" wide slick 30" tall actually had a better tire contact patch than the 10.5 due to the length of the patch, not the width.  That took some thought, but he was right.  Yes, many racers with 9" wide slicks do run in the 9 second range with a well set-up chassis.  Joe-JDC
manofmerc
« Reply #14 on: June 12, 2024, 03:30:46 AM »
No I havent weighted my car on the corners and I am leaving on the trans brake (c-6)Yes joe I have a 29.5 tire I am just missing something .The real deal is if I were to move my springs in to put a bigger tire it would probably hook up just from bigger rubber .But somehow if I can just find a simple solution it would cure my lack of traction .On my trans brake I am leaving at 2800 .The small block guys tell me to leave at 3800 .I tried 3300 spin city .Their small blocks 434 cu.in. dont have my torque Their theory is more rpms load your suspension didnt work for me .My current tire only have 10-12 passes on them also.Next time out I will have new 90/10 shocks I will try a lower setting on my two step less air in the tires (12) psi maybe 4 degrees retard in the dist.Thanks for your comments and help Doug
