Author Topic: Should I be running a different heat range plug?  (Read 5215 times)
6667fan
  • Every Second Counts
« on: June 04, 2024, 07:37:47 PM »
Been running an NGK range 8 for the last two seasons. Engine is burning oil but still running well, frequent plug changes a must. It should come apart but finances dictate otherwise at this time. Which direction, ( plug heat range), might I try?
Thanks.
JB
67 Fairlane 500
482 cid 700/617
10.55@125.74 1.46 60’
galaxiex
Re: Should I be running a different heat range plug?
« Reply #1 on: June 04, 2024, 08:04:16 PM »
Go a little hotter.
It will help to burn off the oil deposits.
