Author Topic: Jay’s B9 reproduction carb  (Read 13867 times)
66FAIRLANE
  • Andy
Re: Jay’s B9 reproduction carb
« Reply #15 on: June 03, 2024, 12:43:08 AM »
 ;D
« Reply #16 on: June 03, 2024, 09:33:50 AM »
Honestly, you guys.  Where is the trust?   ;D
Most of these pictures were taken last fall when I got the cars home.  The dyno pics were taken at the beginning of May
« Reply #17 on: June 03, 2024, 05:30:59 PM »
To update on my end.
I made a bunch of small changes to the calibration so they should run better with his cam.
Also blueprinted the works.
Ran fine
https://www.facebook.com/share/v/daifwD4xKuzKVgFX/?mibextid=WC7FNe
No drama, adjusted fine.
Jay should just be able to set floats, mixture, idle speed, and be good to go.
Guess we will see.
« Reply #18 on: June 03, 2024, 05:33:11 PM »
Oh and sorry if I let the Boss9 cat outta the bag Jay.
At least I posted it in the right forum, not like the Lykins fella showing us Clevelands we don’t wanna see 😂😂😂😂
« Reply #19 on: June 04, 2024, 06:44:20 PM »
Wow, two Boss 429's!  I think you did better in the long run, the GT sure didn't have much of a depreciation cycle but i'm guessing it won't go up too much more.
« Reply #20 on: June 04, 2024, 06:58:23 PM »
The one is certainly a survivor! I would not even consider painting it. They are only original once, despite the engine being rebuilt. But it's not my car.
« Reply #21 on: June 06, 2024, 11:00:36 AM »
LMAO , yah don't be like that trouble maker Lykins guy
« Reply #22 on: June 10, 2024, 04:32:33 PM »
I got Drew's carb installed and running over the weekend.  Took it out for a test drive today and it works beautifully.  Thanks Drew!
« Reply #23 on: June 10, 2024, 06:15:52 PM »
Oh good, happy to hear.
I hate when these little details get ignored… simple parts, simple problems.
Let me know if I can help get it dialed in as you go, happy to help.
bsprowl
    • Ford FE Information
« Reply #24 on: June 20, 2024, 10:48:31 PM »
Today I was looking for something else and stumbled across a 429 SCJ Stick D1ZF-9510-YA Holley I forgot I had.  List number R-6127A, with the 6382 and 5672 metering blocks, rebuilt, complete.
« Reply #25 on: July 08, 2024, 10:52:22 AM »
This is why I take all my carbs apart, even new out of the box. I've had to mill bodies to get them to lay flat on the baseplate without a gasket, found trash in the bowls, etc.  I'm not talented enough to know the feed sizes but just cleaning the thing up makes sure you at least start out as close to factory spec as possible.
