Author Topic: Holley Sniper - IAC Rampdown and RPM  (Read 17181 times)
CV355
« on: May 28, 2024, 08:34:26 AM »
I've tried asking this over on the Holley forums but they won't touch the question unless I post datalogging results (can't do that at the moment, my laptop bricked during one of Microsoft's unnecessary hourly updates).  I'm hoping someone might be able to provide me with an explanation on effects of IAC settings:
IAC Hold Position
Ramp Decay Time
RPM Above Idle to Start Ramp
RPM Above Idle to Start Idle Control
https://www.manualslib.com/manual/1379721/Holley-550-407.html?page=48
These are self-explanatory in function, but my question is- what are the negative effects of having these parameters adjusted incorrectly?  I am facing an intermittent RPM hanging and surging issue.  There were multiple factors to it (BOV adjustment and vac leak, needed stronger springs on the TB as it was sticking open at 5%, and AC kick was on for some reason), but I have solved a few and narrowed it down to just IAC tuning at this point.  If I let off the throttle with the engine up to temp, the IAC% hangs at the hold position and refuses to ramp down unless I blip the throttle (start ramp rpm issue, right?).  Really fun when you're approaching a busy intersection and the engine is fighting the brakes.
I adjusted the IAC hold from 20% down to 10%, Ramp from 4s to 2s, and RPM start ramp from 1000 to 1250.  This reduced the issue but didn't solve it.  I've been told that the RPM start ramp needs to be higher, but I don't fully understand what will occur if this is set too high or other values too aggressive.  The rampdown itself makes sense- too aggressive and it'll make decel jerky, too gentle and RPMs hang.  I don't want to overcompensate for one issue and create new issues.
Re: Holley Sniper - IAC Rampdown and RPM
« Reply #1 on: May 28, 2024, 09:38:58 PM »
IAC Hold is where the IAC parks once you give it throttle, if it's too high it won't idle down easily
Ramp Decay is the time it takes to relax from the hold point once the throttle returns
RPM above idle is where it starts to settle
RPM above idle to start idle control is when the IAC takes over actively, not the ramp down
I think your idle speed to start ramp was high, and you went higher. That will essentially ease the idle starting at that point
However, logs are your friend, going to need to get that working again to really figure it out
66FAIRLANE
  • Andy
« Reply #2 on: May 29, 2024, 03:28:27 AM »
Without going out to the shed and looking I believe this is what I use
IAC Hold Position 10%
Ramp Decay Time 2s
RPM Above Idle to Start Ramp 1700rpm (I believe Holley recommend starting at 1000 above idle in the manual)
RPM Above Idle to Start Idle Control (150rpm)
CV355
« Reply #3 on: May 29, 2024, 06:59:01 AM »
I did test the idle speed to start ramp parameter down to 500 to see the effect (1325 total).  It resulted in an angry, erratic idle of about 1400rpms, like the engine was loading up to launch.  So, I changed it in the other direction to 1250 (2075 total) and it settled down immediately as IAC dropped to 0%-2%.  My idle is set at 825 in neutral, about 7xx in gear.  Any higher and it diesels at shut down.  Any lower and it shakes the car apart and feels like it's going to stall out at red lights.
I agree, I need to get that laptop fixed so I can datalog.  Microsoft has been awful lately with pointless and damaging updates (practically every phone call I get on for work has someone mentioning how recent updates wreaked havoc, but I digress...)
What would the negative effect be if the idle speed to start ramp is set far too high?
« Reply #4 on: May 29, 2024, 01:05:45 PM »
I have not tried it, but thinking this through
- If the throttle is returning and the IAC is at the hold point (parked), the "ramp" for when the IAC takes over is a function of time and start and stop points.  Should literally look like a ramp with RPM on the Y axis and Time on the X axis.
- The RPM points on that graph are RPM Above Idle to Start Ramp (high limit) and RPM Above Idle to Start Idle Control (low limit)
- The time or rate it drops is ramp decay, or how fast to get across those two points above (seconds)
If RPM Above Idle to start Idle control was too high, I think your IAC would have to unscrew really quickly then screw back in very quickly (it's a small motor that drives a vacuum leak)
If I misunderstood your question and you were asking if RPM Above Idle to Start Ramp was too high.  I would think it would make the ramp less steep and slow throttle return.
I have not played with these values enough to know how much matters.  My hunch is you had something with the low start ramp causing the IAC to cycle back and forth into the ramp, but it is just a WAG
Ramp Decay Time 2s
These settings seem very logical to me, start the ramp 1000 above idle, end it at just above idle, which ends up to be very close to where the IAC is parked (10%) and it takes over
CV355
« Reply #5 on: June 10, 2024, 06:54:35 AM »
I updated the settings as recommended above, and the issue is now completely resolved.  Zero RPM hang, IAC is operating properly, and the drive quality was far better.  Thanks guys!
CV355
« Reply #6 on: July 08, 2024, 06:55:57 AM »
Quick update...  The issue came back after a few more drives.  The issue only occurs when the engine is up to temp, and I confirmed that IAC% is no longer the issue.  Previously, IAC would hang at 20% and the car would lightly accelerate with no weight on the throttle pedal.  Since correcting IAC parameters in this thread, that factor of the issue is gone.
Now, IAC is at 0% and the engine hangs from 1500-2000rpm depending on gear.  I could not get the engine to idle down and had to drive home 10 miles without touching the accelerator pedal.
I'm trying to acquire a laptop so I can do some data-logging, but looking for ideas as this is not safe to drive.  I'm going to check the idle set screw again.  It idles fine when cold though, so I'm not sure that could be the issue.  Any ideas?
1)  BOV is operating fine
2)  Extra spring on throttle return, confirmed it's not binding with heat
3)  IAC Parameters set properly
4)  No vac leaks- vac gauge was fine and matched TPS%
Katz427
« Reply #7 on: July 08, 2024, 08:24:16 AM »
Talking to a in-law, who once worked for holley, his comment was check the secondaries,  they have a tendency to stick, just slightly open. He says it has been a problem, for a while.
CV355
« Reply #8 on: July 08, 2024, 08:37:12 AM »
That would do it...  I may add a spring there to help draw them back so it isn't just the linkage - easy to test.  It would also explain why it only happens when at full operating temp.
I appreciate the insight!!
CV355
« Reply #9 on: July 08, 2024, 09:24:02 AM »
Found this thread on that topic- wanted to link it here in case anyone else stumbles on this thread:
https://fepower.net/simplemachinesforum/index.php?topic=7595.0
66FAIRLANE
  • Andy
« Reply #10 on: July 08, 2024, 09:56:05 PM »
I believe a lot of people with this issue just put an extra wind on the secondary spring.
Are you still running a factory PCV?
« Last Edit: July 08, 2024, 09:59:59 PM by 66FAIRLANE »
CV355
« Reply #11 on: July 09, 2024, 06:47:51 AM »
I can try that.  I did put an extra return spring and extension on the primary throttle linkage.  I may fab up a bracket to add another spring to the secondary shaft.  I don't mind a stiff gas pedal at all.
As for the PCV, no, not factory.  I have a Billet Specialties PCV and breather cap, PCV running to a Moroso catch can.  Catch can runs to a 3/8" NPT vac manifold fed from the Sniper base.  I'm seeing about 12" vac at idle, maybe 22" of vac when coasting at no throttle.
66FAIRLANE
  • Andy
« Reply #12 on: July 10, 2024, 12:33:42 AM »
Is that Billet specialties PCV variable like a factory unit? One of the things I did was to replace the factory style with a fixed orifice one. Considering the IAC is a variable vacuum leak (albeit computer controlled) I did not like the idea of another less controlled one complicating matters at idle. From memory I think I am using around a .080 orifice.
CV355
« Reply #13 on: July 10, 2024, 07:38:29 AM »
I believe it is fixed, but I will check.
« Reply #14 on: July 10, 2024, 10:02:53 AM »
I believe any sort of intermittent vacuum leak would show in an IAC post Orion log with low IAC numbers.
It sounds like hanging secondaries to me given no odd logs
