Author Topic: Jegs Order Cancellation  (Read 2156 times)
hwoods
« on: May 23, 2024, 07:39:44 AM »
after almost one year, order placed on June 30-2023, Performance Automatics Cancelled my order for a PA26390  bellhousing, C4 Trans to FE engine.
I was given multiple ship dates since then, but wanted the part.  I thought it was a good price basis what I was seeing from anyone that claimed to have one available to ship.  I have a Qucktime bellhousing, but believed the PA bellhousing offered better access to the torque convertor than the Quicktime.
I had in the past even reached out direct to PA, but they would never respond to me.
mike7570
Re: Jegs Order Cancellation
« Reply #1 on: May 23, 2024, 11:13:26 AM »
I have the Quicktime bellhousing on my 428 with a C-4 trans. There is no access to tighten the torque converter nuts so I just drilled an access hole a little larger than the socket I needed through the 1 piece spacer/cover  in line with the converter studs. No problem with installing.
