Author Topic: Another internet FE build  (Read 2920 times)
DuckRyder
« on: May 16, 2024, 08:14:30 PM »
https://www.youtube.com/watch?v=RPz00cvo2jI
This should be interesting....
Robert
Re: Another internet FE build
« Reply #1 on: May 16, 2024, 08:46:02 PM »
That video makes you appreciate anything Brent or Barry puts on the internet.  He definitely needs to prepare some notes to keep his thoughts in perspective and keep on track.  A lot of time for no real information.  Joe-JDC
« Reply #2 on: May 17, 2024, 06:56:14 AM »
Not sure how he gets nearly 11.5:1 compression calculation.
Using Diamond's calculator (decent third party data) I get 10.86:1 with .010 deck clearance, a Fel-Pro 1020 gasket and assuming a .010 cut below nominal spec on the deck.
Above also assumes a .250 crevice volume, and the Mahle specified 7cc dome volume.
If - a big if - the block had actually been honed with a torque plate, you would need to have a torque plate installed to properly measure bore diameters.
« Last Edit: May 18, 2024, 07:00:51 AM by Barry_R »
428kidd
« Reply #3 on: May 17, 2024, 07:30:07 AM »
First time ive ever heard anyone say that a 428 was thicker than a 390 or 360 block.
