Author Topic: NEW HYDRALIC COMP CAMS HYDRAULIC ROLLER SET  (Read 3729 times)
Dubs1
« on: May 13, 2024, 10:53:09 AM »
FOR SALE
NEW NEVER USED SET OF COMP CAMS  FE  HYDRAULIC ROLLER SET.
ASKING $450/offer   plus shipping
Larry     ltduba@hotmail.com    (720) 839-3477
HarleyJack17
Re: NEW HYDRALIC COMP CAMS HYDRAULIC ROLLER SET
« Reply #1 on: May 13, 2024, 05:09:02 PM »
Do you have the cam specs/ number?
Dubs1
« Reply #2 on: May 15, 2024, 09:04:32 AM »
The specs are as foliows;
gross valve lift    INTAKE      EXHAUST          PART  3        33-000-11   SN  #   l  0199-16
                            .600          .622          GRIND #    FB  3316r     3317r
DURATION
TAPPET LIFT .006  287           .293
VALVE TIMING       OPEN              CLOSE
                   .050    INT  11    BTDC   45  ATDC
107.0    INTAKE CENTERLINE
DURATION   @   .050      INTAKE           EXHAUST
                                         236               242
LOBE LIFT                       .3470              .3600
LOBE SEPARETION    112.0
hbstang
« Reply #3 on: June 19, 2024, 05:14:26 PM »
just to clarify things,is this the cam and hydraulic roller lifters both for $450?
