Author Topic: Lykins Motorsports 461ci Clevor, Pump Gas, 720hp  (Read 4469 times)
« on: May 11, 2024, 08:02:02 AM »
Did this one a few years ago, but it's a good indicator of what the "street" Clevors can accomplish.
Performance Summary:
      Cubic Inches:    461           Dyno brand:  Stuska
      Power Adder:   Doesn't need one      Where dynoed:  Dale Meers Racing Engines
      Peak Horsepower:  720 @ 6700
      Peak Torque:  630 lb-ft
Engine Specifications:
   Block brand, material, finished bore size, other notes:  Dart aluminum, 4.155" bore size, 9.500" deck
   Crankshaft brand, cast or forged, stroke, journal size: Scat Superlight 4.250"
   Connecting Rods brand, material, center to center distance, end sizes, bolts:  Callies Compstar 6.250"
   Piston brand, material (caster, hypereutectic or forged), dish/dome volume, static CR:  Diamond custom, 22.5cc dish, 11.25:1
   Main Bearings, Rod Bearings, Cam Bearings brand and size:  Clevite coated main/rod, Dart coated cam
   Piston rings brand, size, other notes:  Total Seal .043/.043/3mm, light tension
   Oil Pump, pickup, and drive:  Melling, ARP, Moroso
   Oil pan, windage tray, oil filter adapter:  Moroso front sump, no  tray
   Camshaft brand, type (hyd/solid, flat tappet or roller), lift and duration (adv and @.050"):  Custom Lykins Motorsports solid roller, 266/275 @ .050"
   Lifters brand, type:  Crower oiling
   Timing chain and timing cover:  New replacement Ford timing cover, Cloyes billet timing set
   Cylinder heads brand, material, port and chamber information:  Ported CHI 3V, 225cc (before porting)
   Intake valve brand, head size, stem size:  Ferrea titanium 2.190"
   Exhaust valve brand, head size, stem size:  Ferrea titanium 1.65"
   Valve springs brand, part number, specs:  Manley 270/700
   Retainers and locks brand, part number, specs:  Manley titanium
   Rocker arm brand, type (adjustable or non-adj), material, ratio:  Comp Cams Ultra XD, 1.73
   Rocker shafts and stands, brand, material:
   Pushrods brand, type, length:  Trend
   Valve covers, brand, type:  Blue Thunder
   Distributor brand, advance curve information:  MSD
   Harmonic balancer brand: ATI
   Water pump brand, type (mechanical or electric):  Moroso electric
   Intake manifold brand, material, porting information:  CHI 3V
   Carburetor(s) brand, type:  Quick Fuel BDQ-1050
   Exhaust manifolds or headers brand, type:  Dyno headers
Re: Lykins Motorsports 461ci Clevor, Pump Gas, 720hp
« Reply #1 on: May 11, 2024, 08:19:28 PM »
Nice Brent. With that cam with that duration is it streetable with the 11.25 to 1 detonation wise. I had 11.75 to 1 in my first FE and was streetable.
« Reply #2 on: May 12, 2024, 04:58:08 AM »
Yep, guy put it in a ‘64 Galaxie.
