Author Topic: Valve Spring Question  (Read 2764 times)
Diogenes
« on: May 07, 2024, 07:24:10 PM »
I'm trying to find either a Trickflow valve spring, p/n 51400413, or a readily available equivalent. It seems the Trickflow number may be obsolete. The corresponding retainer seems available, a 51400423, but not the spring.
My previously suspected rod knock now appears to be a broken spring and bent pushrod. I'm trying to source these numbers, which were in the paperwork from the previous owner/machine shop. The Trickflow spring 51400413 and Pioneer valve lock PF613HD are documented. The retainer p/n 51400423 I surmised from Trickflow documents found on the web that matched it to the fore-mentioned spring.
The cam is a Bullet 230 dur @ .050, lobe lift .3027 I and E, gross lift .524 I and E.
Any other p/n's would be greatly appreciated. I'm hoping to source these locally so I can quickly confirm this was my problem, and not something requiring rebuilding the short block.
1985 Toyota Celica Supra
1989 Texas DPS Police Mustang
1971 Torino GT 351C 4V AT
pbf777
Re: Valve Spring Question
« Reply #1 on: May 08, 2024, 10:37:46 AM »
      From here, I can't really comment of the the other products, but if you run it hard, perhaps you might want to consider different valve locks?    ;)
      Scott.
Diogenes
« Reply #2 on: May 08, 2024, 05:12:25 PM »
I found the numbers
The valve locks and retainer actually did their job quite well.
