Author Topic: Loud starter  (Read 2656 times)
fiveseven
Loud starter
« on: May 04, 2024, 10:34:19 PM »
HI I rebuilt  the 390 also new flex plate. When it cranks its really loud and the starter gear is stuck in flexplate. Replaced starter and flexplate same condition, i also tried shimming starter same thing. Anyone have thing problem before and what can be done .. It has a C6.
GerryP
Re: Loud starter
« Reply #1 on: May 05, 2024, 06:23:47 AM »
Is there a steel plate between the engine block and the bellhousing?  That steel plate is what aligns the starter by piloting the starter.  I am assuming you are working with a '64 or later assembly.  Earlier assemblies use a pull starter Bendix without a block plate.
