Author Topic: Bullock's Power Service - pump gas 430cid ALL iron CJ - 480HP / 511TQ  (Read 4791 times)
Performance Summary:
      Cubic Inches:  430           Dyno brand: Stuska
      Power Adder:  N/A             Where dynoed:  Dale Meers Racing, Buffalo, KY
      Peak Horsepower:  480@6000
      Peak Torque:  511 @ 3300
Engine Specifications:
   Block brand, material, finished bore size, other notes:  1968 C scratch 428, 4.150 bore, CnC squared, aligned, torque plate honed
   Crankshaft brand, cast or forged, stroke, journal size: Factory cast 3.98
   Connecting Rods brand, material, center to center distance, end sizes, bolts:  Molnar H beam 6.49
   Piston brand, material (caster, hypereutectic or forged), dish/dome volume, static CR: Racetec, 11 cc dish, 10.05:1
   Main Bearings, Rod Bearings, Cam Bearings brand and size:  Clevite rod and main bearings, Durabond cam bearings
   Piston rings brand, size, other notes: Mahle 1mm/1mm/2mm standard tension
   Oil Pump, pickup, and drive:  Melling M57B, factory pickup, ARP drive
   Oil pan, windage tray, oil filter adapter:  Factory 68 CJ, factory tray unmodified, factory oil filter adapter
   Camshaft brand, type (hyd/solid, flat tappet or roller), lift and duration (adv and @.050"):  Custom Bullock's Power hydraulic roller, 229@.050 intake
   Lifters brand, type:  Morel standard travel
   Timing chain and timing cover: Early Comp (supplied by owner), factory cover
   Cylinder heads brand, material, port and chamber information:  C8OE-N CJ, 11/32 SI valve, minor bowl blend, 2.19 intake, 1.70 exhaust, Viton seals, spring locator cups
   Valve springs: Trick Flow 160/390
   Rocker arm brand, type (adjustable or non-adj), material, ratio:  Precision oil pumps, 1.76, adjustable
   Rocker shafts and stands, brand, material:  Precision Oil Pumps
   Pushrods brand, type, length:  Trick Flow 8.600 oiling
   Valve covers, brand, type:   68 CJ/GT chrome
   Distributor brand, advance curve information:  Factory 68 CJ with Pertronix, 12 initial, 38 total
   Harmonic balancer brand:  Stock, restored
   Water pump brand, type (mechanical or electric):   Stock rebuilt 68 Ford  - electric powered on dyno
   Intake manifold brand, material, porting information:  Untouched and unported CJ C80E-9425-A
   Carburetor(s) brand, type:  Peak power made with 750 dyno carb, but w/in 5 HP with correct CJ 735
   Exhaust manifolds or headers brand, type:  Dyno headers
« Last Edit: May 03, 2024, 05:31:42 PM by My427stang »
Nice Ross is that going in a factory 428 car should scoot right along
Yes sir, 68.5 fastback, 4 speed.
On edit - here is a cleaned up video from the owner
Glad he could, it is a pretty engine
https://www.youtube.com/watch?v=mtgO0UFeXIA
« Last Edit: May 07, 2024, 07:13:26 AM by My427stang »
