Author Topic: A couple of FEs with actual weights  (Read 2387 times)
« on: May 01, 2024, 03:58:16 PM »
I thought you all may find this interesting
459 inch 428, BT intake, iron heads, SCAT crank and I-beams, Racetecs, hyd roller, Morels, alum water pump, no flywheel, no carb, engine stands bolted on, with 7.5 qts oil - 529 lbs
433 inch 428, CJ iron intake, iron heads, Ford Crank, Molnar rods, Racetecs, hyd roller, Morels, iron water pump, no flywheel, no carb, engine stands bolted on, 6 qts oil -582 lbs
Figured I'd weigh them for laughs..off to the pump!  Even a Ram 2500 HD has a little squat with these two big girls in the back!
« Last Edit: May 01, 2024, 03:59:52 PM by My427stang »
HarleyJack17
Re: A couple of FEs with actual weights
« Reply #1 on: May 03, 2024, 02:02:15 PM »
Nice.
