FE Technical Forum
427 Ford Steel Cranks Does Cammer take a different crank?
Topic: 427 Ford Steel Cranks Does Cammer take a different crank? (Read 2916 times)
dozz302
Full Member
April 27, 2024, 02:17:33 PM »
Just wondering if a Cammer takes the same crank as a regular 427? Yes, Cammer would have been steel.
Administrator
Re: 427 Ford Steel Cranks Does Cammer take a different crank?
Reply #1 on:
April 27, 2024, 02:57:38 PM »
The SOHC can use any FE crank.
dozz302
Full Member
Reply #2 on:
April 27, 2024, 07:07:31 PM »
That's what I thought. Wasn't sure if the Cammer came with the "Nascar" crank with the wider rod journals. Thanks
FE Technical Forum
