Author Topic: max spring pressure with aluminum heads  (Read 7431 times)
Jim Comet
« on: April 06, 2024, 02:58:56 PM »
Hey guys, what's the max spring pressure you would run with T&D street rocker set up in aluminum Edelbrock heads. I am set up for 650lbs over the nose. Should I consider putting in time-serts while the heads are off? T&D said it would be no problem, but I worry about pulling a stud out of the head. That's the problem with machining taking too long, it gives a guy time to worry about stuff instead of slapping it together and just running it!!!! Jim
Re: max spring pressure with aluminum heads
« Reply #1 on: April 06, 2024, 06:17:15 PM »
I would put in some inserts, there's really no downside to doing it and you'll get some peace of mind that way - Jay
« Reply #2 on: April 06, 2024, 06:53:26 PM »
I’ve pulled the studs out at 600 lbs of spring load.  When I do aluminum head solid rollers now, I use a different insert or a T&D race rocker.
Jim Comet
« Reply #3 on: April 06, 2024, 08:21:02 PM »
Just went and checked and the holes have full length heli-coils in them. Would you take them out and do time-certs? If so, is there a better brand of insert I should use or just something off the local shelf. Jim
« Reply #4 on: April 06, 2024, 08:21:12 PM »
Same deal here.  My heads have inserts for a reason.  I've pulled threads in aluminum at 610-620.
TJ
« Reply #5 on: April 06, 2024, 08:32:22 PM »
For soft metals like aluminum, might consider key locking inserts.  Time serts sometimes back out with the bolt.
« Reply #6 on: April 06, 2024, 09:42:20 PM »
I use EZ Loks, same inserts I use in my cylinder heads.  I would pull out the helicoils and drill and tap for EZ Loks.  I've had poor luck with Timeserts, have had them crack and come out.  On my tunnel port heads I use EZ Loks with a 9/16-12 outside thread and the 3/8-16 inner thread.  Jim if you want to stop by sometime I will show you what they are like.
« Reply #7 on: April 06, 2024, 09:46:02 PM »
I've had decent luck with the Heli-coils.  I've had time-serts break off at the "hat" - so I do not use them.
Jim Comet
« Reply #8 on: April 06, 2024, 09:48:15 PM »
Thanks everyone. I do have some EZloks. I think I will do like you said on an old post and use an old shaft and pedestals to make jig to accurately drill the new larger holes. I found some 3/4 inch long inserts so they will have thread engagement the whole length of the hole in the head. Thanks, Jim
« Last Edit: April 06, 2024, 09:51:53 PM by Jim Comet »
Tunnelwedge
« Reply #9 on: April 07, 2024, 06:01:54 AM »
When I was drilling holes in some Edelbrocks I drilled the oil drains and cut a bigger oil drain slot.
I pulled the coils out and put in my home made thread inserts.
I also drilled the bolt hole for the oil feed to the rocker. It is a tad smaller than a stock Cobra Jet head.
I was using a 625 lbs spring.
galaxiex
« Reply #10 on: April 07, 2024, 08:24:43 AM »
Here's a fun test of thread repair inserts...
https://www.youtube.com/watch?v=jknMrFOGMOQ&ab_channel=ProjectFarm
Go to approx 10 minute mark to see the pull tests.
Jim Comet
« Reply #11 on: April 07, 2024, 12:00:23 PM »
I watched that. Good info.
« Reply #12 on: April 07, 2024, 12:52:15 PM »
So I guess either one of the inserts are good for 650 lb spring pressure.
1968galaxie
« Reply #13 on: April 07, 2024, 01:11:39 PM »
One must always remember that the spring pressure is not directly below the attaching rocker shaft bolts.
There is that rocker arm which multiplies the 650 lbs (example) of the spring. The rocker arm is a lever, multiplying
the force as seen by the rocker shaft/attaching hardware.
With a 1.76 ratio:
600lbs of force at long end of rocker/lever.
600 lbs X 1.76 = 1056 lbs of force at the short side of the rocker/lever.
The pivot point (shaft centerline) sees 600 + 1056 lbs of force.
No wonder T&D race rockers do not rely on the 4 mounting bolts.
« Last Edit: April 07, 2024, 02:31:52 PM by 1968galaxie »
