Author Topic: Bullock's Power Service - 410C - pump gas 582 HP 545 LB FT  (Read 5507 times)
This was a fun one, admittedly a lot of work fixing some odd things from a prior Cleveland specialist, but in the end a lot of fun and turned out very happy and healthy.  We made a number of runs, all hitting 7K and was happy all morning.  Pump gas and not a ton of overlap will make it very happy in a street Mustang with a Tremec
Performance Summary:
      Cubic Inches:  410            Dyno brand: Stuska
      Power Adder:  N/A             Where dyno'd:  Dale Meers Racing, Buffalo, KY
      Peak Horsepower:  582 @ 6200
      Peak Torque:  548 @ 4800
Engine Specifications:
   Block brand, material, finished bore size, other notes: 72 4 bolt main iron 351C, 4.040 bore, CnC squared, aligned, torque plate honed
   Crankshaft brand, cast or forged, stroke, journal size: SCAT forged steel, internal balance, 4.00 stroke
   Connecting Rods brand, material, center to center distance, end sizes, bolts:  SCAT H beam 6.00
   Piston brand, material (caster, hypereutectic or forged), dish/dome volume, static CR: DSS pistons, -18cc dish, 10.0:1
   Main Bearings, Rod Bearings, Cam Bearings brand and size:  SYandard Clevite rod and main bearings, Durabond cam bearings
   Piston rings brand, size, other notes: Total Seal 1.2mm stainless top, 1.2mm #2, 3.0mm standard tension oil ring
   Oil Pump, pickup, and drive:  Melling M-84AHV, ARP drive, Milodon pickup
   Oil pan, windage tray, oil filter adapter:  Milodon T-pan
   Camshaft brand, type (hyd/solid, flat tappet or roller), lift and duration (adv and @.050"):  Custom Bullock's Hydraulic Roller, 235 @ .050, 114 LSA on 107
   Lifters brand, type:  Morel standard travel hydraulic roller
   Timing chain and timing cover: Cloyes 9 position, factory timing cover
   Cylinder heads brand, material, port and chamber information:  SVO NASCAR B351, ported 225  cc intake, ported exhaust
   Valve springs: Comp 20655 Beehive
   Rocker arm brand, type (adjustable or non-adj), material, ratio:  Jesel 1.75 ratio, pinned
   Rocker shafts and stands, brand, material:  N/A
   Pushrods brand, type, length:  factory
   Valve covers, brand, type:   Unknown fabricated
   Distributor brand, advance curve information:  MSD large cap, 34 degrees total
   Harmonic balancer brand:  Unknown aftermarket
   Water pump brand, type (mechanical or electric):   Unknown stock replacement,  electric powered on dyno
   Intake manifold brand, material, porting information:  Roush SVO   single plane
   Carburetor(s) brand, type:  Dyno'd with 950 QFT and super sucker - 582 HP, customer 830 and no spacer - 572 HP
   Exhaust manifolds or headers brand, type:  Dyno headers
« Last Edit: March 31, 2024, 11:41:57 PM by My427stang »
TurboChris
Re: Bullock's Power Service - 410C - pump gas 582 HP 545 LB FT
« Reply #2 on: April 03, 2024, 05:07:38 PM »
Very healthy!
price5113
« Reply #3 on: April 10, 2024, 02:00:44 PM »
Wow those are some stout numbers from that combo! I'd assume those CYL heads had a heavy hand in the results.........
« Reply #4 on: April 16, 2024, 01:26:01 PM »
They are a stout set of heads, fast intake port, raised exhaust port, very nice single plane intake.  Allowed for very little cam too and should be very easy to drive
