Author Topic: timing mark  (Read 3089 times)
timing mark
« on: March 07, 2024, 07:26:00 PM »
i pulled my ngk plugs out,been getting some popping out the exhaust.i have my timing set on my msd dist. at 33 degree,[bbm heads},as suggested by forum members.i noticed my timing mark is near the tip of the plug,only 1/8- 3/16 from the tip.timing charts shows 2-4 degree too little. what should i do,leave it at 33 or bump it up a couple degree as the pointer could be showing wrong,but its been ok in the past,till i changed ignitions.
GerryP
Re: timing mark
« Reply #1 on: March 07, 2024, 07:43:05 PM »
You want it centered, more or less, on the ground strap.  That is usually a pretty good indicator of how the engine is reacting to timing.  The goal of a tune up is to give the engine what it's telling you it wants.
Re: timing mark
« Reply #2 on: March 08, 2024, 09:43:30 PM »
I have heard changing ignitions could make timing change. Had my motor dyno Ed and when I checked timing it was 3 to 4 degrees less.
Jb427
Re: timing mark
« Reply #3 on: March 09, 2024, 03:53:43 PM »
This may sound silly but have you checked that your getting full 12v to your msd
Just had a friends cleveland swap from points to a rtr msd it was poping and banging and it was just not getting 12v fixed that and runs great now.
Re: timing mark
« Reply #4 on: March 09, 2024, 09:03:57 PM »
Whenever you change MSD ignition boxes(6AL/2) your timing will be different by as much as 4* or so.  I found this out during a dyno session on my EMC engine.  Different 6ALs have different timing.  You may need to re-establish top dead center and 0 on the damper.  Joe-JDC
Re: timing mark
« Reply #5 on: March 10, 2024, 08:36:06 AM »
it had a msd pro billet dist but i put a gm module on it when my last msd box failed
Re: timing mark
« Reply #6 on: March 10, 2024, 09:36:09 AM »
put a new set of ngks in it and it quit popping,i had cold plugs in it , too cold,i went 1 step hotter this time.i had bought some colder plugs for nitrous,but i went too far.pretty sure that was the problem,but i will check my connections and make sure im getting 12 volts,and a good ground.
