Author Topic: CVR water pump question  (Read 3182 times)
sixty9cobra
« on: February 25, 2024, 10:05:57 AM »
I ordered a CVR 8000cl 55 gpm water pump in November and the delivery date was March 15 2024 now it says April.  I was looking at the small block pump 8560cl which is also 55 gpm and its 27 dollars more than the bare pump and it is in stock. Are all the pump and motors the same? Someone on here must have a small block. I could unbolt the stock brackets and bolt on Jays Brackets
Re: CVR water pump question
« Reply #1 on: February 25, 2024, 06:02:42 PM »
Harry, I think they are the same but I'm not 100% sure.  You could buy one and return it if it doesn't fit - Jay
sixty9cobra
« Reply #2 on: February 26, 2024, 09:54:53 AM »
I emailed CVR since that’s the only contact info not even a phone number.
sixty9cobra
« Reply #3 on: February 27, 2024, 03:29:02 PM »
CVR replied small block pump is the same as  8000CL and comes with the lower nipple. Cheaper to buy the small block one and toss the wings and put Jays on. Lesson learned.
« Reply #4 on: February 27, 2024, 04:02:45 PM »
Good to know..
