Author Topic: Valve spring at 8500 rpm.  (Read 2107 times)
Re: Valve spring at 8500 rpm.
« Reply #1 on: February 07, 2024, 04:16:45 PM »
What's really interesting is how much the valve stem itself moves around.  Certainly the head end of the valve is doing the same thing; argues for a lot of radial clearance from the valve to the piston eyebrows...
« Reply #2 on: February 09, 2024, 06:13:01 AM »
I have had an engine where we had a measured +.020 radial clearance between an exhaust valve and the cylinder wall - and had witness marks on the wall after running.
