Author Topic: Fairlane at Sickweek  (Read 2835 times)
Russ67Scode
« on: February 04, 2024, 03:33:23 PM »
Day 0 of sick week ripped the front half of the pinion out of the rear  messed up an axel bearing. Fixed it that night at 1:00 am started up the car and it had no gears we believe it broke the sprag in the trans my week was over before it started 🥲
The run before this pic. I had water leak from the trunk someone said my car was leaking  so the track people backed me up into the water looked under the front and pulled me back into the beams. I let go of the trans brake it went up in smoke I let off it then hooked and the tires were bouncing off the ground. We believe that’s what caused the damage  it just let go on the second pass
hbstang
Re: Fairlane at Sickweek
« Reply #1 on: February 04, 2024, 04:06:17 PM »
i seen your car on a video,that expains why i didnt see it later.tough luck on that.seems that track was super sticky so any week link would fail.
whats your combo on the car?
Russ67Scode
« Reply #2 on: February 04, 2024, 04:06:32 PM »
Here is where it broke zoom in on rear tires they actually came off the ground
https://youtube.com/shorts/goj7UzAluIs?si=vJOocNL6o-HPR3gW
Russ67Scode
« Reply #3 on: February 04, 2024, 04:10:26 PM »
hbstang  the car is on here. "super stock Fairlane". anyway it has a Blair Patrick 520 ci FE with twin turbos FAST EFI C-6 trans and had 3.0 gears. 3640 lbs with me in it
