Author Topic: Difference between solid and hydraulic roller lifters?  (Read 3466 times)
AlanCasida
« on: January 24, 2024, 01:24:18 PM »
Besides the obvious is there any difference in the construction of aftermarket solid and hydraulic roller lifters, particularly in the roller? I am considering changing from a solid roller to hydraulic roller cam in my BBF. I currently have the Comp Endura roller lifters with the EDM oiling to the roller. I read somewhere that Comp recommends replacing their solid roller lifters every 7500 miles. Just wondering if the construction of the hydraulic roller lifters give them a longer life span. Thanks!
Re: Difference between solid and hydraulic roller lifters?
« Reply #1 on: January 24, 2024, 01:30:35 PM »
A hydraulic roller lifter will always live longer (much, much, much longer) because they don't see the spring loads that a solid roller lifter sees and they don't have lash.   The combination of lash and spring load is what makes a solid roller lifter fail.
A hydraulic roller lifter will pretty much live indefinitely.....think of how many 5.0 Mustangs and Explorers that have 100-200k miles on them.
AlanCasida
« Reply #2 on: January 24, 2024, 01:35:49 PM »
I understand that on OEM applications. Is the roller construction of Comp(as an example) the same on their solid and hydraulic roller lifters?
« Reply #3 on: January 25, 2024, 12:45:32 PM »
For the most part.  I don't use Comp lifters, but the wheels and needle bearings should be similar.
AlanCasida
« Reply #4 on: January 25, 2024, 03:19:27 PM »
Thanks for your input, Brent I really appreciate it. What lifters do you use?
« Reply #5 on: January 25, 2024, 03:25:21 PM »
For hydraulic roller, I use Morel.   For solid roller, I either use BAM or Morel.
« Reply #6 on: February 06, 2024, 12:30:21 PM »
I've had good luck with Howards solid rollers in my 351Cs.  I use the pressure oil models.  Some of the Comp units are splash only, I'd for sure stay away from those. IIRC the Howards are rebuildable.  I check mine every year - on a 351C 9.2 deck you can just lift them out without pulling the heads, so easy off season check.
