Author Topic: 427 SOHC blower manifold question  (Read 3931 times)
jl7422
« on: January 18, 2024, 12:43:10 PM »
Hello. I recently acquired a Munro SOHC blower manifold. With the magneto driven off the stub cam on the front of the motor, is a modified distributer body taking the place of a conventional distributer to drive the oil pump shaft in a wet-sump configuration?
thanks!
pbf777
Re: 427 SOHC blower manifold question
« Reply #1 on: January 18, 2024, 03:28:38 PM »
       In the past we have cut down O.E.M. distributor bodies, or bought special "low-profile" bodies (stems) from MSD which we then modified, and then also just turned out our own on the lathe bodies (better as greater fitment options exist), all for the purpose of providing a drive stem-shaft for the mounting of the driven-gear and to turn the oil pump.   :)
       Scott.
pumpbldr
« Reply #2 on: January 18, 2024, 03:51:34 PM »
Here is a picture of one for you. Not very hard.
Doug aka pumpbldr
Precision Oil Pumps
jl7422
« Reply #3 on: January 18, 2024, 04:28:17 PM »
Thanks guys--that's about what I figured I'd need-- I appreciate the help.
Leny Mason
« Reply #4 on: February 05, 2024, 09:56:26 AM »
I cut down a FE distributor housing and put a bearing in it and setscrewd in place there is not much room under the manifold, make sure You put the right gear to match the cam you are running
« Last Edit: February 05, 2024, 09:58:28 AM by Leny Mason »
