Author Topic: Ford Adjustable Rockers  (Read 3642 times)
« on: January 10, 2024, 02:29:27 PM »
What is the highest lift anyone has reliably run with these stock rockers?
Re: Ford Adjustable Rockers
« Reply #1 on: January 10, 2024, 03:46:15 PM »
I'm interested in spring pressures with solid rollers, too.
« Reply #2 on: January 10, 2024, 04:11:55 PM »
I have ran factory rockers at .660" lift and 425 lbs of spring load.   That was with a rules road race engine with REM/cryo rockers.
No way I'd ever associate a factory rocker with a solid roller.
« Last Edit: January 10, 2024, 04:19:00 PM by blykins »
MeanGene
« Reply #3 on: January 10, 2024, 05:49:22 PM »
I ran a 296/.660 Delong solid with Isky 8005-A springs many moons ago
« Reply #4 on: January 10, 2024, 06:06:51 PM »
Like some of the others, I have also ran a solid flat tappet cam with factory adjustable rockers, with over .650" lift. t was an old Comp Cam, I believe the exhaust lift was either .678 or .687" lift. That was in the late 70s-early 80s, wasn`t a lot of alternatives back then.Never hurt a rocker arm but did break a few shafts, no end supports back then.
« Reply #5 on: January 10, 2024, 07:33:07 PM »
That you, all, I appreciate it.
I've got some Bullet lobes picked out that give a net lift of .688/.704. They are as low as I can get with the duration I want. It's for Jay's TP heads. I'm going to try for 7mm SS valves.
I'm hoping I can use a roller but, I can't afford T&D rockers, that's why I'm asking.
MeanGene
« Reply #6 on: January 11, 2024, 10:08:53 AM »
The Isky rockers are quite a bit beefier, and have a hardened tip insert
