Author Topic: CVR water pump dimensions  (Read 3884 times)
sixty9cobra
« on: December 28, 2023, 05:14:46 PM »
 Hi, guys, I am upgrading my cooling system with a triple pass crossflow radiator. I am using two Spal 12-inch fans. I also ordered Jays water pump adapters for the CVR pump. The pump won't be available till March. There doesn't seem to be a lot of room in there. Can someone give me the dimensions mostly the height or the distance from the block mount to the tip of the motor, and the diameter of the motor?
                                Thanks in advance Harry
Re: CVR water pump dimensions
« Reply #1 on: December 28, 2023, 09:46:33 PM »
Harry, the nose of the water pump motor is almost identical in position to the nose of the stock FE water pump; they both stick out about the same amount from the block.  Diameter of the CVR motor is 4".
sixty9cobra
« Reply #2 on: December 28, 2023, 10:09:42 PM »
Thank you Jay that helps a lot. I can proceed now without knowing that I’m not wasting my time.
« Reply #3 on: December 28, 2023, 11:28:09 PM »
Nice Harry good job. You can always get the answers that you need here.
« Reply #4 on: December 29, 2023, 05:54:00 AM »
You may receive it quicker than that.  I ordered one last month and it showed up a few weeks later.
sixty9cobra
« Reply #5 on: December 29, 2023, 09:59:07 AM »
Thats good news Brent I thought the supply issues were over..
