Author Topic: Innovators West integral timing pointer and crank trigger bracket  (Read 3284 times)
philminotti
I saw this item at PRI this year and decided to get one.
The first picture is the original arrangement, which was fine.  The IW unit is pretty sweet though.  Needed a bit of massaging, but all good.
« Last Edit: December 21, 2023, 08:19:07 PM by philminotti »
Urgefor
Re: Innovators West integral timing pointer and crank trigger bracket
« Reply #1 on: December 21, 2023, 09:55:32 PM »
Looks almost as good as Jay's trigger.  :D  How long has IW had that setup available?
« Reply #2 on: December 21, 2023, 10:39:04 PM »
I think that is my trigger wheel on there, and my sensor bracket in the first picture.  The Innovator's West unit is nice if you have to reposition the sensor for fit reasons, and it adds some bling too.  Of course, EFI software allows you to change the actual trigger point of the sensor, so a fixed bracket will always work, as long as it fits in the engine compartment.
philminotti
« Reply #3 on: December 22, 2023, 06:58:02 AM »
Yes Jay, that's correct.  And your heads too, lol. Hell, the original timing pointer was the only OEM Ford part on the engine.  Now that's gone.
IW has had this setup for quite awhile.  I've just never seen it used.
« Reply #4 on: December 23, 2023, 07:49:58 AM »
Been around a while but with a few changes.  The balancer didn’t use to have the reluctor wheel on it.  Nice pieces.  I use them on racy stuff.
« Reply #5 on: December 23, 2023, 08:40:40 AM »
Yes indeed, good stuff. Been using them for quite a while. Got a new setup on the bench now for the new build. Good company to work with to. In the past they would do extra keyway  grooves and custom bores at a reasonable upcharge in a timely manner.
