Author Topic: CVR Water pump inlet tubes  (Read 2493 times)
bsprowl
    • Ford FE Information
« on: December 15, 2023, 01:31:42 PM »
No one has these inlet tubes.
Would a Morso inlet 62522 fit?
mike7570
Re: CVR Water pump inlet tubes
« Reply #1 on: December 15, 2023, 04:04:35 PM »
I bought a different style inlet tube from Summit. They show some Meziere fittings in stock with the -12 o-ring to hose barb in different sizes.
might be something there that would work. I also see various CVR inlet tubes on Amazon.  Good luck.
« Last Edit: December 15, 2023, 04:28:50 PM by mike7570 »
« Reply #2 on: December 15, 2023, 10:01:29 PM »
Bob, have you tried going directly to CVR?  Link below...
http://www.cvrproducts.com/product-category/proflo-accessories/billet-inlet-fittings/
Mr Woodys Garage
« Reply #3 on: December 18, 2023, 11:41:15 AM »
Good Luck With Finding Them. Jay Zolko Customized The Longer Version Of One Of These Tubes I Was Lucky Enoough To Get Earlier This Year. (Had To Settle For The Red Pump, As Thats All Summit Had Left)  The Shorter Version Was Required To Work With Jays 2 Piece Timing Cover. He Did Some Diligent Mock Up, And Put An Angle In It When He Welded It Together. Turned Out Nice, Don't You Think? I Also Had Him Add A Port In The Passenger Side Adapter For A Heater Hose Fitting, If One Is Desired In The Future, And Some Additional Ones On The Other Adapter For Temp Sensors For Possible Future Use. Both Jays Make Some Nice Stuff!
« Last Edit: December 18, 2023, 01:19:30 PM by Mr Woodys Garage »
bsprowl
« Reply #4 on: December 18, 2023, 01:06:53 PM »
They apparently don't sell direct.  I emailed them; they told me their re-seller was Summit.  I ordered from Summit, shipping is estimated for Feburary 29th.
CVR suggested I have it dropped shipped and I'm trying to get that to happen.
