Author Topic: FE Crane cam id  (Read 3788 times)
Hiriser57
FE Crane cam id
« on: November 05, 2023, 09:13:23 PM »
Have old crane cam.  Only number on rear of cam  304-2F
Can anyone provide specs   Thanks
Re: FE Crane cam id
« Reply #1 on: November 06, 2023, 02:53:03 AM »
I have a '81 Crane catalog, that lists a Blazer 304-2F.
304/314, 238/248 @ .050, 114 LSA, .563/.586 gross lift, .026/.026 lash.
Says it operating range is 3k - 6.5k. Sounds like a good early cam (split wise) but, 81° of overlap and 86° ICL. I'd advance it 6 - 7°, for 79° ICL. Even at 79° ICL, it can  take 11/1 CR
« Last Edit: November 06, 2023, 06:54:46 PM by frnkeore »
475fetoploader
Re: FE Crane cam id
« Reply #2 on: November 06, 2023, 08:24:34 AM »
I would think the idle produced by this cam would be pleasant.
1967  519 c.i.  TKX 5 speed
Re: FE Crane cam id
« Reply #3 on: November 06, 2023, 03:55:37 PM »
Back in it's day, it would make others think, before they want to put their foot down against it.
Slow lobes, so, probably not to bad on springs.
Hiriser57
Re: FE Crane cam id
« Reply #4 on: November 06, 2023, 08:16:40 PM »
Thanks   Had a 1977 and 1991 Crane catalog didn't see any listing for this cam.  Might stick it in a street engine just for the heck of it.
Hiriser57
Re: FE Crane cam id
« Reply #5 on: November 06, 2023, 08:21:13 PM »
also have a Howard FE cam, only number on rear in Howard 295.  Got these given to me, hate to throw them away I guess.
1968galaxie
Re: FE Crane cam id
« Reply #6 on: November 06, 2023, 10:02:43 PM »
Perhaps this Howards cam?
https://www.howardscams.com/hydraulic-flat-tappet-camshaft-1963-1977-ford-352-428-3000-6400-howards-cams-250981-10
Year: 1963 - 1977
Make: Ford
Engine: 352-428
Camshaft Type: Hydraulic Flat Tappet
Basic RPM Range: 3000 to 6400
Valve Lift Intake: .548
Valve Lift Exhaust: .548
Duration Intake: 295
Duration Exhaust: 295
Duration at 050 Intake: 241
Duration at 050 Exhaust: 241
Lobe Separation: 110
Intake Centerline: 106
Firing Order: 1-5-4-2-6-3-7-8
Quantity: 1 Each
Country Of Origin: United States
