Author Topic: Good deal on steel flywheels  (Read 9148 times)
c-reed
« on: November 04, 2023, 08:10:51 AM »
Not mine but if anyone is looking for one seems like a great deal
https://www.ebay.com/itm/285538925907?hash=item427b723d53:g:
gdaddy01
Re: Good deal on steel flywheels
« Reply #1 on: November 04, 2023, 07:26:45 PM »
thanks, just ordered one
Mark Bliss
« Reply #2 on: November 05, 2023, 09:31:05 AM »
I don't see any weights advertised.
Am I overlooking it?
gregb
« Reply #3 on: November 05, 2023, 10:00:08 AM »
Says 34 pounds in the description.....
« Reply #4 on: November 05, 2023, 03:25:15 PM »
And for external balance.
Mark Bliss
« Reply #5 on: November 05, 2023, 05:34:13 PM »
Ah. So I did indeed miss it.
Mark Bliss
« Reply #6 on: November 05, 2023, 05:37:25 PM »
The counterweight appears to be removable, so perhaps it could be neutral balanced...
And on that subject, I can't remember which configurations were externally balanced. 428? (Time flies and the memory fades)
« Reply #7 on: November 05, 2023, 06:02:14 PM »
If it's removable, you should be in good shape.
410/428 were externally balanced.
pbf777
« Reply #8 on: November 06, 2023, 11:47:28 AM »
      Do note: that with 'just' the removal of the additional bolt-in counter weight, this may not (very likely won't!) actually make the flywheel "neutral"; though likely provides that it could be more easily made such.   ;)
      Scott.
Mark Bliss
« Reply #9 on: November 06, 2023, 02:11:49 PM »
Agreed.
« Reply #10 on: November 06, 2023, 03:51:02 PM »
In manufacturing, the FW would pretty much, have to be made neutral, to know how much weight to bolt on and how far from center, that would include bolt holes and bolts.
pbf777
« Reply #11 on: November 06, 2023, 06:36:46 PM »
In manufacturing, the FW would pretty much, have to be......................
     But, were pretty much guessing here, right?   :-\
     Now, just for thought: what about the empty threaded holes provided for in the retention of the counter-weight when it's removed?   ;)
     Scott.
« Reply #12 on: November 07, 2023, 02:22:07 AM »
Note the additional single hole, 180° from the weight and further out on the diameter.
« Last Edit: November 07, 2023, 02:26:48 AM by frnkeore »
Mark Bliss
« Reply #13 on: November 07, 2023, 05:48:32 AM »
Good eye Frank.
I did not see that, but now I do!
« Reply #14 on: November 07, 2023, 08:12:20 AM »
I grabbed one, looks a lot like the McLeod bolt on weight design that allows both internal or factory external.  I'll spin it on the next build, I will a Fidanza alum and a Ford Racing that need true zer, won't take but a few minutes minute to bolt this one on
That being said, I wouldn't worry about using it in either configuration.  Correct it when you balance the engine, or match balance it to what you pulled off, easy-breezy
