Author Topic: Which part # for scat crank  (Read 2470 times)
BigBlueIron
« on: October 30, 2023, 04:01:29 PM »
Trying to stock pile parts as they are available for an upcoming build, 428 based. 4.25 stroke 6.7 rod BBC journals. A cast crank should be well enough as I'm only shooting for an honest 500hp. But which part number do I need? 9-FE-4250-6700-2200? Seems they have about 15 variations.
 Ill use either Molnar or K1's. I figure I will end up with a custom piston so just trying to collect what I can in the mean time. Once the block and heads are verified then I can adjust the piston as needed to fit the build. If anyone has a part number for the Molnar's that would also be much appreciated.
Re: Which part # for scat crank
« Reply #1 on: October 30, 2023, 04:15:30 PM »
That is the correct part number for the crank.  CH6700VTB8-A for the rods.
BigBlueIron
« Reply #2 on: October 30, 2023, 04:27:26 PM »
Thanks for the verification Brent.
Mr Woodys Garage
« Reply #3 on: October 31, 2023, 06:39:39 PM »
I Had Brent Order The H Beam Rods From Molnar For Me. The Price And Service Was Great, And They Arrived Promptly. When They Were Weighed, Measured, Etc. For Balance And Assembly, Their Quality Was Quite Evident! They Are Nice Pieces, And I Would Highly Recommend Them For A Strong, But Budget Friendly Build.
