Author Topic: Final TNT for season at local track  (Read 17821 times)
6667fan
  • Every Second Counts
« on: October 28, 2023, 06:23:50 PM »
Fortunately there was a rescheduled test n tune Friday. So many rain outs here in the Northeast this summer/fall. Was going to go two other times this month but Ma Nature said forget it.
Managed a new low ET even with a poor 60’. Went 10.68, mph of 125.71. 60’ was only a 1.56. Car has 60’ 1.46. Problem was my line lock was wonky. Only one good burnout all day, car would just slide. The good burnout netted a 1.52 on a different pass.  So I feel car has a 10.5 in it but won’t find out this year.
« Last Edit: January 28, 2024, 08:03:20 PM by 6667fan »
JB
67 Fairlane 500
482 cid 700/617
10.55@125.74 1.46 60’
Re: Final TNT for season at local track
« Reply #1 on: October 28, 2023, 08:56:29 PM »
Awesome! I agree, with that mph, it should do a 10.50. Making some good power...
« Reply #2 on: October 28, 2023, 09:32:38 PM »
Sweet what track in the northeast.
6667fan
« Reply #3 on: October 28, 2023, 10:21:48 PM »
Joe, it’s Lebanon Valley in New York. Kinda a straight shot out of Western Ma for me, (1.5 hours one way). Next closest track is an hour more, going east instead of west into New Hampshire.
JB
67 Fairlane 500
482 cid 700/617
Posi67
« Reply #4 on: October 28, 2023, 11:41:25 PM »
In spite of what "should" be true there is no rhyme or reason to ET/MPH/ 60' relationship in my experience. Some of my best ET's have come from less than stellar 60' times. I blame that on the driver however. Start line spin usually equates to a slightly higher MPH because you effectively have taken a running start to the finish line.
It is a given that you can't MPH without HP and looking at your setup I'd be expecting something in the 130 range. My stuff is very similar although I suspect my car is lighter but even my 390 runs 132 MPH and it's not at your HP level. Nonetheless, good that you got some last runs in and went home in one piece. One question, what back tire do you run?
6667fan
« Reply #5 on: October 29, 2023, 07:24:24 AM »
Dale, the slicks are a 29 x 10.5 Hoosier. D06 compound. Run them anywhere from 13.5 - 12.5 psi. Car is is 3650 with driver and 1/2 tank. I recall you sharing the relationship,( or lack thereof), between mph and ET in the past when I lamented that the car is not quick enough for its mph. Most of that is the driver here.  So I’m looking for help from the equipment, lol. Figured a decent 60’ would at least find me a tenth off the ET.
This trip was the first time out with my Viking DAs in the front. Wheelies are tiny now, front end more under control. The old 90/10s had the car pogoing one through third. I had the rebound setting on 4, then 2. Might try 0, the 90/10s were very good on extension but the compression was laughable on my car.
Thanks much for weighing in.
JB
67 Fairlane 500
482 cid 700/617
« Reply #6 on: October 29, 2023, 02:27:13 PM »
Would like to go to that track next year. I’m sure some of my buddies will make the trip. I will let you know. Maybe I will meet you there.
6667fan
« Reply #7 on: October 29, 2023, 03:23:03 PM »
That would be awesome Joe. That would double or maybe triple the number of FE powered machines there at one time, lol.
JB
67 Fairlane 500
482 cid 700/617
manofmerc
How did you get those 10.5 slicks on there ??
« Reply #8 on: November 05, 2023, 06:24:45 AM »
As the title says 6667 how did you do that .My comet is tight with 29x9s .Just asking Because I have been fighting traction problem all year with my 502 (460 based) comet .I just got my convertor back from ATI it was loosened up .Thanks and good results for you keep at it young man!!!Doug
351crules
« Reply #9 on: November 05, 2023, 09:25:40 PM »
what is your rear suspension set up like? trap rpm? i do agree the mph should be higher with the hp. do the rpms drop a lot during shifts? what rpm was peak power?
6667fan
« Reply #10 on: November 05, 2023, 10:51:28 PM »
Doug, the 10.5s only fit with a rear spring relocator kit and judicious slicing of the inner fender well and the outer inner wheel lip. The outer lip is not rolled, just relieved along with the wheel house trim. On the inside the snubbers and perch were excised back to the inner well. The rims are 15 x 10s with a 5.5” backspace. The Strange housing is 1.5” narrower than stock.
351crules, the trap rpm is 7K and the shifts are at 6800-6900 Peak power is at 6600. Without powershifting the Rs drop bit but have to check logger to see by how much. Engine is tired, not likely 630+ hp at this point. That value came from a fresh build on a numbers friendly dyno.
The rear set up is Caltrac bars with their split mono leafs. Also their 9 way adjustable shocks.
JB
67 Fairlane 500
482 cid 700/617
Jb427
« Reply #11 on: November 06, 2023, 01:09:02 AM »
I thought more people would be using a drag radial these days 275 50/60 15 can fit them on 8 to 10 inch wide rim. 275 on a 8 inch rim should fit under stock diff if you got the right rim back space
475fetoploader
« Reply #12 on: November 06, 2023, 08:28:11 AM »
I was going to throw my 2 cents in, and tell you about my 295/65/15 that fits snug, but fits. I have ladder bars though. So all the issues caused by leaf springs, aren’t there.
1967  519 c.i.  TKX 5 speed
6667fan
« Reply #13 on: November 06, 2023, 05:27:33 PM »
Tried drag radials early on. This driver could not make them work with even low rpm clutch dumps. If I had a two pedal car I would try them
JB
67 Fairlane 500
482 cid 700/617
« Reply #14 on: November 06, 2023, 06:55:14 PM »
Concerning "drag radials", I am not aware of anybody that has been happy with them on a clutch car with some power, and hard launches. Dropping the clutch on a stick car is a whole different thing than an automatic. I do know some guys that have tried radial drag slicks with a stick, they may get a good run now and then, and the next time, it blows the tires off on the launch. Radials seem to work very well on a car that dead hooks, but thats not how a clutch car usually works best. A clutch car usually wants a revolution or 2 on the launch, and radials do not recover as well as a bias slick does.
