Author Topic: Sold BBM 482  (Read 3668 times)
mn67
Sold BBM 482
« on: October 19, 2023, 08:49:37 AM »
I am selling my 427 stroker project. Going with a different FE combination. At this point I have more engines than cars and need to get a shop built before I start on anymore. Also have just about everything to put this completely together and will make a package deal if someone is interested. I would really prefer to sell this as a local pickup.
BBM Block 4.25 stroke 4.25 Bore
Scat H Beam Rods
Scat Steel crank 4.25
FE power Adjustable timing chain and timing cover
Bullet Cams FE 287/293-10A Lift- int .688 ex .688 - int 287 ex 293. @.050 int 254 ex 260. Separation 110
Icon pistons
All machine work and assembly done by T.E.S in Bloomington MN.
$8300.00
Parts that can go with as a package or will be kept/listed once the short block sells.
BBM Heads ported by Janderson Heads in MN.
Morel 6164 lifters
Valves 2.19 int 1.68 ex
Comp Valve springs tool steel retainers
FE power Intake adapter and Weiand tunnel ram (Port matched and machined by Janderson)
FE power CVR water pump adapters
2 Quick fuel 750 dp
Harland Sharp shafts and rockers
Moroso t-pan
Precision oil pumps, Oil pump
valve covers etc.
Thanks Mike - fshgy at hotmail.com
Edited to remove crower lifters that were incorrectly listed. And carb linkage I can't locate.
« Last Edit: November 09, 2023, 09:34:33 AM by mn67 »
1971 Maverick Grabber
bsprowl
    • Ford FE Information
Re: BBM 482 Shortblock $8300.00
« Reply #1 on: October 19, 2023, 11:24:24 PM »
Private message sent.  I would pick it up.  (I need a road trip.)
JacksFordParts
« Reply #2 on: October 21, 2023, 07:53:19 PM »
That's a great buy for someone
Nbrhdkid
Re: Sold pending pick up: BBM 482 Shortblock $8300.00
« Reply #3 on: November 07, 2023, 08:28:01 AM »
Is the top end parts still available? Cyl heads/rockers
bsprowl
« Reply #4 on: November 08, 2023, 10:03:06 AM »
I bought it all.
I already had a Offy tunnel, the adapter and two Holley 850 center squirters so those are for sale.
I have listed some of that here already.
« Last Edit: November 08, 2023, 10:05:50 AM by bsprowl »
