Author Topic: Bullock's Power Service - 428 PI 391 HP / 460 TQ, stock head pump gas  (Read 5460 times)
Performance Summary:
      Cubic Inches:  439             Dyno brand: Superflow
      Power Adder:  N/A             Where dynoed:  Fremont Automotive Machine, NE
      Peak Horsepower:  391 @ 5200
      Peak Torque:  460 @ 4000
Engine Specifications:
   Block brand, material, finished bore size, other notes:  C scratch 428, 4.190 bore, sonic checked, squared decked, align honed, torque plate honed
   Crankshaft brand, cast or forged, stroke, journal size: Factory 428
   Connecting Rods brand, material, center to center distance, end sizes, bolts:  Ford w/ ARP  3/8 bolts
   Piston brand, material (caster, hypereutectic or forged), dish/dome volume, static CR: DSS, 15cc,  9.96:1
   Main Bearings, Rod Bearings, Cam Bearings brand and size:  Clevite rod and main bearings, Durabond cam bearings
   Piston rings brand, size, other notes:  Mahle 1/16, 1/16, 3/16 standard tension, Napier second
   Oil Pump, pickup, and drive:  Melling M57HV, Milodon pickup, ARP drive
   Oil pan, windage tray, oil filter adapter:  Milodon, no tray, standard 90
   Camshaft brand, type (hyd/solid, flat tappet or roller), lift and duration (adv and @.050"):  Howard's 226/238 112 on 107, .580 lift
   Lifters brand, type:  Morel standard travel
   Timing chain and timing cover: Cloyes 9 position, factory timing cover
   Cylinder heads brand, material, port and chamber information:  C6AE-L, no port work, bronze guides, 11/32 stem
   Valve springs brand, part number, specs:  977-16, 155/405
   Rocker arm brand, type (adjustable or non-adj), material, ratio:  Factory adjustable
   Rocker shafts and stands, brand, material:  Precision Oil Pump end stands
   Pushrods brand, type, length: Smith Brothers, ball/cup, 8.225
   Valve covers, brand, type:   Painted pentroof
   Distributor brand, advance curve information:  Ford 427 dual point converted to Pertonix, 38 total
   Harmonic balancer brand:  Factory 428  rebuild
   Water pump brand, type (mechanical or electric):  Iron, engine powered on dyno with alternator
   Intake manifold brand, material, porting information:  C6AE-F PI, unported
   Carburetor(s) brand, type:  3310-1 Holley, rebuilt, outsourced by owner
   Exhaust manifolds or headers brand, type:  Dyno header, short truck style into 3 inch collectors and 2 into 1 dyno muffler
Re: Bullock's Power Service - 428 PI 391 HP / 460 TQ, stock head pump gas
« Reply #1 on: October 15, 2023, 09:53:20 PM »
This is a very interesting one, kept C6AE-L heads on it as they were correct for the restored police car.  However, they are an emissions head (small port, low exhaust), nothing was ported or blended, and the compression is a true 9.96:1.  Cam matched fora 3.00 C6 4 door actual police cruiser.  Should be a very fun "highway pursuit" car!
« Reply #2 on: October 16, 2023, 09:22:08 PM »
So basicly a stock rebuild with a cam. 3.00 gear and a c-6. That’s what I had in my mustang when I first got it with a 427. Had the B cam I believe the one with 306 duration, man that thing would pul forever. Idle at 800 in gear. Nice build Ross.
« Reply #3 on: October 16, 2023, 10:07:33 PM »
Thanks, its a nice runner, certainly sounds fierce!
https://www.youtube.com/watch/6Hy0a-Ew85o
« Last Edit: October 16, 2023, 10:18:36 PM by My427stang »
DuckRyder
« Reply #4 on: October 17, 2023, 11:08:56 AM »
Nice, I presume with the Morel Lifters that's a hyd roller?
Be the car is cool too...
Robert
« Reply #5 on: October 20, 2023, 12:38:48 PM »
Yes, hyd roller.  Normally I do not use shelf cams (not sure if I can say that after 2 in a row LOL) but this was a Howards hyd roller.
