Author Topic: Brake Booster 1963 Colony Park  (Read 4170 times)
ChiefDanGeorge
« on: October 08, 2023, 04:55:57 PM »
I've been tracking down a brake leak and found out the master cylinder was leaking into the brake booster. I managed to snap the plastic nipple that the vacuum line hooks to. Does anyone know if I can get a replacement for it. In the shop manual it's called a Vacuum Manifold.
Also, how the heck do I removed it from the brake booster? I think it's just a rubber grommet that holds it from the inside. I'm trying no to break anything else so I don't want to start pulling and mess up the booster. Looks like the brake fluid was only in the bellows, which I assume would mean the bellows are still fine.
GerryP
Re: Brake Booster 1963 Colony Park
« Reply #1 on: October 08, 2023, 05:49:57 PM »
The fitting is held into the rubber grommet with nibs on the fitting.  It will come out pretty easily with a screwdriver between the flanges.  There are replacements available.  Your booster should be okay if you clean out the brake fluid.  Soapy water should do the trick.  No solvents.
ChiefDanGeorge
« Reply #2 on: October 09, 2023, 05:47:48 AM »
So just take a screw driver and pry up from the outside, making sure to catch the grommet on the inside?
GerryP
« Reply #3 on: October 09, 2023, 07:14:07 AM »
Put a screwdriver blade between the flange of the plastic manifold and the lip of the rubber seal and pop the manifold up.  It is a lot easier than you are thinking.  It comes right out.
ChiefDanGeorge
« Reply #4 on: October 10, 2023, 04:00:43 PM »
Yep, it just popped out.
Now, any idea of where to source one?
GerryP
« Reply #5 on: October 10, 2023, 04:52:11 PM »
It's very common.  Here's the most common:  https://www.rockauto.com/en/parts/dorman,80190,power+brake+booster+check+valve,1876
The ones with the second nipple are also around.  Just do a search for it.
1964Fastback
« Reply #6 on: October 10, 2023, 05:33:32 PM »
If you are replacing the booster hose, make sure to use hose made for this.  If you use heater hose or similar, it's liable to collapse.
Pat
ChiefDanGeorge
« Reply #7 on: October 15, 2023, 09:05:08 AM »
As an FYI, that is not the right part, the brake booster I have has a much larger port. I'd ordered the Dorman 80189 piece since it came with 2 grommets, but those don't solve the size issue either.
The part number I need is: C4AZ-2365-A, found it here: https://www.macsautoparts.com/1961-1971-ford-thunderbird-power-brake-booster-check-valve-66-36174-1.html however I'm trying to see if there is a solution that will work with a more readily available valve.
ChiefDanGeorge
« Reply #8 on: October 15, 2023, 04:26:11 PM »
Don't listen to me, the 80189 will work, you have to stack the 2 grommets. Not the best solution, but it will work.
