Author Topic: Moroso T oil pan capacity  (Read 6921 times)
FirstEliminator
« on: July 04, 2013, 01:44:21 PM »
   Hey guys,
   The final pieces are going on an engine I've been putting together for a while. One of the questions I am trying to find an answer to is with the oil capacity. The engine has the Moroso T style oil pan. I cannot find what the capacity is supposed to be. The dipstick that came with the oil pan is adjustable.  So I need to put in the correct amount of oil then adjust the dip stick height and tighten it down. If anyone knows, I'll be checking back frequently today.
   thanks,
      Mark
Mark
Berkshire Transmissions
North Adams, Massachusetts
70 Cougar XR-7 460 C-6
69 Cougar SS 351w AOD
69 Cougar XR-7 390 C-6
68 Monterey 390 C-6
68 Monterey conv 390 C-6
58 Monterey 383 Merc-O
58 Parklane 430 MultiDrive
68 Colony Park 428 C-6
68 Colony Park 390 C-6
I don't feel like a hoarder.
Re: Moroso T oil pan capacity
« Reply #1 on: July 04, 2013, 02:51:53 PM »
I don't know the capacity offhand, but I would guess it is close to a Cobra T-pan, which is 7 quarts.  Do you have a stock dipstick?  If so, you could just plug that in for the initial measurement, and then adjust your aftermarket dipstick accordingly...
« Reply #2 on: July 04, 2013, 05:09:52 PM »
http://www.summitracing.com/parts/mor-20607/overview/make/ford
8 quarts for that one, and typically Moroso does not include the filter in their capacities.
rcodecj
« Reply #3 on: July 04, 2013, 05:15:26 PM »
I have the Moroso #20608 steel t pan.
It is 8 quarts without oil filter.
FirstEliminator
« Reply #4 on: July 13, 2013, 02:38:11 AM »
    Thanks guys.   The engine is installed and running. I will have to post some pics.
Mark
68 Monterey 390 C-6
fe66comet
« Reply #5 on: July 13, 2013, 10:09:53 AM »
I have the 8 quart pan, do I have nine in the bucket then? I am adding a cooler and accumulator along with dual filters so that will be determined after I run it.....Jon
