Author Topic: Ported/Assembled Tunnel Port Heads & Intake, Other Parts For Sale  (Read 5411 times)
Guys, going a different direction with a dyno mule.  Have some parts up for sale:
1.  Fully ported/assembled Tunnel Port heads.  These were baked/tumbled, fitted with 5/16" bronze valve guides, custom stainless SI 2.250"/1.750" valves, and then ported by Joe Craine. Flow numbers are as follows:
.100      80.54      58.49
.200     159.49     105.62
.300     238.48     146.24
.400     300.82     189.52
.450     320.87     192.76
.500     341.37     197.62
.550     356.53     199.89
.600     360.98     204.10
.650     368.11     207.34
.700     374.35     215.44
The ends of the heads have been drilled and tapped for drain fittings (currently plugged).  They have also been assembled with PSI valve springs, Manley titanium retainers, and Manley titanium locks.   Springs are CT1226, 1.460" diameter, setup at around 200 lbs seat and 525 lbs open, which would be good for a short travel hydraulic roller lifter or mild solid roller camshaft.  There is one exhaust flange ear that looks to have had a factory repair.
To go with the heads is a fully ported single carb Tunnel Port intake.  It flows an average of 490 cfm.  Has been vapor blasted, no paint or coating.
I will take $5000 for the assembled heads and intake.   Any reasonable/fair offers will be entertained.  This is a big power making combination.
2.  Complete Aviaid external wet/vac pump setup with modified C8AX oil pan.  Pan is obviously not new, but the Aviaid parts are all brand spankin new.  Comes with a drive mandrel/spacer, billet mounting block, pulley, fittings, etc.  $1200
3.  Meziere polished electric FE water pump, brand new.  $475
4.  Holley 8082 1050 Dominator, completely refurbished/recolored by Drew Pojedinec.  $750  Can get pictures on request.
Re: Ported/Assembled Tunnel Port Heads & Intake, Other Parts For Sale
« Reply #1 on: August 12, 2023, 11:32:10 AM »
Carburetor is sold.
« Reply #2 on: August 15, 2023, 03:09:07 PM »
HEADS AND INTAKE ARE SOLD
