Author Topic: Edelbrock Pro-Flow for FE  (Read 2922 times)
FirstEliminator
« on: July 19, 2023, 01:39:11 PM »
   Hi,
     Anyone using the Edelbrock Pro-Flo for the FE?    It comes on a Victor style intake. I prefer this EFI configuration over the Sniper, FItech or MSD Atomic drop on EFI.   Currently I am using the MSD Atomic EFI, while it works pretty good most of the time the one thing I don't like is the injectors are above the throttle plate. At idle while looking down the throttle body there is a nice mist coming out of the boosters then the mist lands on the closed throttle blades forms into droplets and gets sucked into the  plenum. This seems to be making a dirty idle. A carb has a cleaner idle than this style EFI. FAST EFI appears to have their injectors below the throttle plate which should have a cleaner idle than the other 3.
    While I might go back to a carb, the Pro-Flow is somewhat intriguing. Especially if my wife is driving the car. EFI requiring less driver input makes it a little easier on her.
    Thoughts? Experiences?-----------thanks.
Mark
Berkshire Transmissions
North Adams, Massachusetts
70 Cougar XR-7 460 C-6
69 Cougar SS 351w AOD
69 Cougar XR-7 390 C-6
68 Monterey 390 C-6
68 Monterey conv 390 C-6
58 Monterey 383 Merc-O
58 Parklane 430 MultiDrive
68 Colony Park 428 C-6
68 Colony Park 390 C-6
I don't feel like a hoarder.
JamesonRacing
Re: Edelbrock Pro-Flow for FE
« Reply #1 on: July 24, 2023, 12:32:03 PM »
I have a PF4 on my 363" small block.  Not a bad system, but isn't as flexible or tunable as the Holley systems.  It's a bargain if you don't have a manifold already, but likely won't perform measurably better than the throttle-body setups.
« Reply #2 on: July 25, 2023, 06:19:09 AM »
https://fepower.net/simplemachinesforum/index.php?topic=8981.0
Mark, it’s been doing just fine, but see the link above
Hard to beat Holley though, programming is so much nicer
FirstEliminator
« Reply #3 on: July 27, 2023, 05:02:02 PM »
Wow Ross, that was quite a detailed endeavor. Before posting my question, I searched Edelbrock Pro Flow here, and I didn't see that thread didn't come up in the search.  Thanks for the link.
Mark
68 Monterey 390 C-6
