Author Topic: Pushrod hole size in 2x4 intakes  (Read 2241 times)
jholmes217
« on: June 16, 2023, 12:44:14 PM »
Are the pushrod holes in the Ford medium riser 2x4 intake the same size as the Blue Thunder medium riser 2x4 intake?  I have a Ford 2x4 medium riser, and I'm using a POPs roller rocker system with POPs pushrods, which are thicker than the original Ford pushrods.  Seems the holes in the Ford intake are awful small to use the POPs pushrods.
« Last Edit: June 20, 2023, 10:13:11 PM by jholmes217 »
Jeff
4 speed, 3:50 traction lock
Olympia WA. area
Re: Pushrod hole size in 2x4 intakes
« Reply #1 on: June 16, 2023, 02:10:29 PM »
I didn't measure the pushrod hole diameter when I tested all the intakes, but I'm about 90% sure they are the same size, 5/8" diameter - Jay
cleandan
« Reply #2 on: June 17, 2023, 09:11:34 AM »
I agree with Jay.
I have not measured the pushrod holes either, but they do appear to be 5/8".
I seem to remember the Blue Thunder intakes are machined a tiny bit larger on the valve cover side of the pushrod hole, almost as if they were beveling it just a bit to be sure the clearance is best.
The Ford intakes have a straight cut hole that is the same top to bottom.
