Author Topic: Headers  (Read 4951 times)
dmazz
Headers
« on: June 28, 2013, 12:40:17 PM »
I'm looking for a set of headers for 8 bolt exhaust heads, need them for dyno time in August, call Denis 7249727320 in south western PA Thank you
dmazz
Re: Headers
« Reply #1 on: June 29, 2013, 07:35:24 AM »
Headers are needed for a 66 Fairlane 4speed non power steering 427 with low riser heads. I'm running 6113 Hookers on a 390 currently. I don't want take the car apart until winter and I'm having the 427 dynoed in August, the shop doesn't have headers for any FE's. Thought maybe someone has a set they're not going to use. Thanks
lovehamr
Re: Headers
« Reply #2 on: June 30, 2013, 08:33:01 AM »
Denis, just be aware that most car headers aren't going to work with most dyno set-ups.  Guess how I know.  At any rate, after going through the same thing that you are (re. the lack of FE anything out there in the world of the small block chebby) I wound up using my Cobra's headers to get the job done.  Definitely not optimum for the job but it's also what I have in the car, so............
You may have to get a set of old headers then cut and re-angle the head tubes to clear the under engine area where it'll be attached to the dyno cart.
This is mine on a DTS dyno.
dmazz
Re: Headers
« Reply #3 on: July 01, 2013, 07:03:39 AM »
lol, Thanks for the help I always said anybody can work on a chevy!
