Author Topic: Ford Toploader  (Read 2335 times)
482supersnake
Ford Toploader
« on: June 10, 2023, 09:21:23 PM »
Anyone ever heard of a toploader with a HEH-CR tag? Friend is looking at one and the seller says it is a special ford race trans but he can't find any info.
Re: Ford Toploader
« Reply #1 on: June 11, 2023, 12:54:45 PM »
I have a pretty good listings of TL numbers but, that one, isn't in them.
Here are my listings of HEH trans:
482supersnake
Re: Ford Toploader
« Reply #2 on: June 11, 2023, 04:16:20 PM »
Yep, he has those charts. I know I've heard of special transmissions before but I'm not a expert on numbers.
Re: Ford Toploader
« Reply #3 on: June 11, 2023, 08:18:17 PM »
I worked at T&C Livonia during the time the Toploader was just starting to go into the production cycle. My 2-month-old '64 Custom/427 was delivered with a T-10 in it. I twisted off the ouput shaft one evening while granny-shifting into 2nd (it was very likely in process of failure prior to the actual break) and it didn't make good sense to simply replace the output and put the T-10 back in place.
I talked to Bruno Zava, the Executive Engineer for the plant, and he had a new toploader delivered to Bill Brown Ford where the work was being completed. I had to go to another dealer to get such items as the proper clutch disc, replacement TO bearing and clutch fork and the DS front yoke to fit the big in-'n'-out Trans (truck parts) but I never had another problem with the trans. The new Toploader was delivered to the dealer with my name on it and no ID tag. Several years later in a trade I got a new special big in-'n'-out with a very short output shaft and extension. It was put together for a then-new 427 race Cobra. It didn't have a tag on it either. I was surely not the only guy in the plant that knew Bruno.
428kidd
Re: Ford Toploader
« Reply #4 on: June 12, 2023, 08:07:01 AM »
The 64 and 65 big spline TL where big in little out only, wasn't until 66 until you actually see a real big in big out.
