Author Topic: 520 inch MEL  (Read 5298 times)
Royce
520 inch MEL
« on: May 27, 2023, 08:15:12 PM »
My final MEL build..
462 Block, offset ground stock crank. Scat rods, Ross Pistons, Performer RPM intake adapted from a 385 series.  Joe Craine ported heads,  215/177 valves.. Custom hydraulic roller from Comp..9.5 compression. Distributors are getting hard to find so I used an old Mallory dual point. Holley 800 carb.. I limited the RPM to 5500, since it was an all stock valve train.  Cranked out some real impressive torque. Sold the engine to a guy in Boston.. Kinda wish I had kept it
1961 Starliner 390/375 clone
1965 GT40 tribute w/FE
1992 BMW V-12 5.0
2001 Lincoln 5.4 4 cam
2000 Jaguar XK8 (Ford V8)
351crules
Re: 520 inch MEL
« Reply #1 on: May 27, 2023, 09:51:03 PM »
awesome
Re: 520 inch MEL
« Reply #2 on: May 28, 2023, 08:55:07 PM »
Royce, why do you say "final"?
That torque curve is pretty impressive. Looks like it would make an excellent towing engine if it could stand a regular fuel diet. Or something that could fry tires without straining anything. Did you keep the dual points or convert it to electronic?
Royce
Re: 520 inch MEL
« Reply #3 on: May 28, 2023, 10:14:18 PM »
Final, because I sold all my MEL engines and parts to a guy in Boston, And I have moved on from my MEL phase lol.. I wish I would have had the dyno guy pull it down to 3000 to find peak toque..   It would probably run on pump gas.. I was surprised by the torque.. It makes approx 30 more horsepower vs a few yrs ago when I dynoed it with a flat tappet cam..
1992 BMW V-12 5.0
Re: 520 inch MEL
« Reply #4 on: May 28, 2023, 10:46:29 PM »
Well done
pbf777
Re: 520 inch MEL
« Reply #5 on: May 30, 2023, 12:20:58 PM »
      That's why they were nicknamed the "Bulldozer"!   :)
      I'm guessing you turned the stock cast crank to BBC 2.200" or.............?   :-\
      Scott.
Royce
Re: 520 inch MEL
« Reply #6 on: May 31, 2023, 07:17:21 AM »
Yes  ended up with a 4.21. stroke  Scary if you think about it.  lot of meat removed. Another reason to limit it to 5500
1992 BMW V-12 5.0
